Wiser for KNX unable to connect with mobile app
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Wiser for KNX unable to connect with mobile app
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2021-07-23 05:57 AM . Last Modified: ‎2024-07-14 11:46 PM
2201
Hello
I'm unable to connect to app with google play application "Wiser for KNX". Is there compatibility matrix?
Wiser version 2.3.0
Server and client in same network. I can access device from web.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Mobile App
  • Wiser for KNX
Erwin-vd-Zwart
Janeway
Posted: ‎2021-08-31 05:30 AM . Last Modified: ‎2021-08-31 05:32 AM
2124
You mentioned 3671 (ETS port) but the topic states moblie app, what is exactly blocked?
Remote programming from an external IP is still blocked due to security reasons in FW 2.6.1 and 2.6.2, there is a solution in progress but not released yet.
The reason why you can connect to the office is probably because you have a VPN tunnel running to the office and the connection is concidered as local.
BR,
Erwin
Replies 18
Thomas_Rohde
Sisko
Posted: ‎2021-08-10 01:43 AM
Hello Piotr,
is this topic still open?
Kind regards
Thomas
Application Design Engineer
Erwin-vd-Zwart
Janeway
Posted: ‎2021-08-10 01:53 AM
2190
There are some updates released in the past, so i would advise to upgrade to 2.6.0 first and i think that will solve your issue…
PiotrJakubczyk
Sisko
Posted: ‎2021-08-10 02:21 AM . Last Modified: ‎2021-08-10 02:24 AM
2186
Should client install FW 2.6.0 or 2.6.1 ?
How to determine if client have hardware  3.x.x or 2.x.x or 1.x.x
PetrMares
Commander PetrMares Commander
Commander
Posted: ‎2021-08-10 02:25 AM
4
2181
there is a side label on the device or you can take a look in flashys page upgrade firmware dialogue window
imx28 means HW1.xx
imx6 is HW2.xx and 3.xx
Erwin-vd-Zwart
Janeway
9
2178
If you need remote programming over 3671 you should use 2.6.0, due to cyber security reasons this is not possible on 2.6.1, there is an update in the pipeline to enter a remote IP but until then i would advise 2.6.0
Erwin-vd-Zwart
Janeway
Posted: ‎2021-08-10 02:27 AM
2176
And another option is just try a FW, if it’s not the correct one it won’t be accepted 😉
PetrMares
Commander
Posted: ‎2021-08-10 02:29 AM
2170
that's good one, Erwin 😄
Thomas_Rohde
Sisko
Posted: ‎2021-08-18 11:09 PM
2151
Hello Piotr,
is it working now?
Kind regards
Thomas
PiotrJakubczyk
Sisko
Posted: ‎2021-08-20 07:05 AM
Still no. But I think it is our partner specific problem. They don't have time and are expecting me to go to end customer and make all work, so temporary case is suspended..
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-08-23 01:19 AM
2143
hello @Erwin-vd-Zwart
I have this issue I install V2.6.1 "Cant program vai 3671" I think it's an IT issue and the IT man check the setting from his side several times 😞
is there a way to overcome this limitation in the current 2.6.1 version?
and does cybersecurity affect the email because the SL stops sending emails?
BR
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-08-23 02:42 AM
7
2138
For remote programming there is an update in development so we can add 1 external IP address that is allowed to connect via 3671, This update is still under review by the cyber security team, as holidays are ending i expect it quite soon now..
For mail, i have no indication so far that mail is affected by changes…
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-08-31 05:22 AM . Last Modified: ‎2021-08-31 06:21 AM
2127
Thank you @Erwin-vd-Zwart
I tried to connect remotely on our office SL V2.6.1 and it's connected. How?
but I have an issue on a site with a firewall that the remote connection not working on the same version (2.6.1)!
while the IT open the ports, while when they try to add the 3671 port on the DMZ they find it blocked!
Best Regards,
Erwin-vd-Zwart
Janeway
2125
BR,
Erwin
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-08-31 05:32 AM
2121
I connected Via 4G Hot spot mobile data!
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-08-31 05:34 AM
2119
This won't mean your PC is not running VPN software, the hotspot is just your GW to the internet, so that makes no difference when using VPN software
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-08-31 05:38 AM . Last Modified: ‎2021-08-31 05:52 AM
2117
I reply to this post because I see you mentioned the 3761 ETS programming port here
regarding VPN we don't have a VPN  at all!
I just want to be 100% Sure its either firmware or firewall blocking the 3671 remote connection port
regards,
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2021-08-31 07:00 AM
2103
Are you sure the device in your office is running 2.6.1 and not 2.6.0?
In theorie you shouldn't be able to connect over a public IP to port 3671 when running 2.6.1
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2021-08-31 11:44 PM
yah its 2.6.1
If you wish we could test it together
this is my email: khalil@ic-systems.ps
Best Regards,
