Wiser KNX The automation cannot be opened
SpaceLogic KNX Forum
Select a Country
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Wiser KNX The automation cannot be opened
Thomas_Rohde
Thomas_Rohde Champion
141
Erwin-vd-Zwart
Erwin-vd-Zwart Champion
64
Heribert_Dölger
Heribert_Dölger Leader
36
Back to SpaceLogic KNX Forum
IC_Systems
IC_Systems
Mentor
Posted: ‎2024-11-24 12:49 AM . Last Modified: ‎2024-11-24 06:08 AM
966
Hello dears,
my customer face the following issue.
when he tried to edit the automations built he got the following message!
how to solve it?
Best Regards,
  • Mobile App
  • SpaceLYnk
  • Wiser for KNX
FZetina
FZetina Leader
Leader
Posted: ‎2024-11-25 03:25 AM
Hello
The error message is shown when for a certain automation, either the actions or the conditions are empty. This is normally not possible to be done from the app because the automation would not be able to be saved, but  If the user created the Automation from the app, and then edits it in the controller or in swagger (APIS).
So from the controller, edit the automation and complete it, or delete it and create it again from the App.
thanks
Fernando Zetina
Erwin-vd-Zwart
Champion
Posted: ‎2024-11-24 10:14 PM
940
@IC_Systems
I guess the answer is already given in the error, logon to the controller and i would try to goto the automation tab, update it there or delete it and create it from scratch.
IC_Systems
IC_Systems
Mentor
Posted: ‎2024-11-25 01:02 AM
@Erwin-vd-Zwart  thank you for your response
but why this issue happened, is there a way to solve it without rebuild the automation again
I see that the scene triggered in this automation only exist on the SL and not appear on the Wiser app, while this scene was build by the user using the Wiser app!
this might be the issue, but how to sync the scenes?
Best Regards,
FZetina
FZetina Leader
Leader
Hello
thanks
Fernando Zetina
