Wiser KNX Group Objects are not visible
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Wiser KNX Group Objects are not visible
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Ozturker
Ensign Ozturker
Ensign
Posted: ‎2025-10-03 01:50 AM
613
Wiser KNX is not showing the group objects. It happened recently. Group objects are working but from Chrome Browser the list is empty.
How we can get them back
Best Regards
  • Thumbnail of Wiser for KNX : logic controller
View products (1)
  • Gateways and Hubs
Replies 4
Erwin-vd-Zwart
Janeway
Posted: ‎2025-10-06 09:10 PM . Last Modified: ‎2025-10-06 09:25 PM
575
@Ozturker
I have seen this a few weeks ago, reason there was caused by Ixon VPN router, are you behind a VPN device and if yes have you tried local connection?
I also see a high CPU load that might cause the controller to be unresponsive, you need to do something on that high load (optimize cyclic traffic, optimize scripts, use filters, use virtual objects, remove unused imported objects to reduce unnecessary telegram processing, etc), stay below the 1..
Ozturker
Ensign Ozturker
Ensign
Posted: ‎2025-10-07 10:57 AM
Thank you Erwin,
I have checked the VPN and made sure that there is none. So I am on the same network. I have stopped all the scripts and now have a very reasonable CPU load. I carried out a reset. But still no objects. Any other suggestions?
Ozturker
Ensign Ozturker
Ensign
Posted: ‎2025-10-09 09:26 AM
Hi Erwin,
I have tried to go back to the old back ups but the issue is the same. I cannot access to the group objects. Please see the guidance on LM forum. Should I go for a sd card reflash? If so could you please share the guidance for Wiser.
Ozturker
Thomas_Rohde
Sisko
Posted: ‎2025-10-28 06:29 AM
Hello Ozturker!
Sorry for the late reply! Is your topic still valid?!
Please let me know so that we can restart with your topic.
Kind regards
Thomas
Application Design Engineer
