Wiser For KNX and Alexa APP voice control
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Wiser For KNX and Alexa APP voice control
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
AmrMustafa
Ensign AmrMustafa
Ensign
Posted: ‎2022-02-01 04:49 AM . Last Modified: ‎2024-07-14 11:45 PM
15
2215
I have a problem to use Alexa APP in my country to make voice control with SpaceLynk or wiser 100100
this app "Alexa" isn't available to use in my country,
Are there other apps to use instead of the Alexa app to make voice Control?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Thomas_Rohde
Sisko
Posted: ‎2022-02-03 04:19 AM
2178
Hi AmrMustaffa,
yes clear, I just wanted to make sure that you have in mind that it works, if available in your country, only with Wiser for KNX and not with spaceLYnk.
Kind regards
Thomas
Application Design Engineer
Replies 15
FZetina
Commander FZetina Commander
Commander
Posted: ‎2022-02-02 01:58 AM
2197
Hi
The Voice Control support for Wiser for KNX with Alexa and Google is currently limited to few countries (Germany, France, Italy, Spain, Portugal, etc). The services in other countries may not be supported by those 3rd party platforms. Please let us know which country you're in.
Thank you
Fernando Zetina
Thomas_Rohde
Sisko
Posted: ‎2022-02-02 02:08 AM
2195
Hi AmrMustafa,
to ".... to make voice control with SpaceLynk or wiser 100100"
Please keep in mind that the voice control function works only with W4K (LSS100100) and NOT with spaceLYnk (LSS100200).
Kind regards
Thomas
AmrMustafa
Ensign AmrMustafa
Ensign
Posted: ‎2022-02-02 04:22 AM
Egypt
AmrMustafa
Ensign AmrMustafa
Ensign
Posted: ‎2022-02-02 04:23 AM
2190
hi Thomas
I asked about which Voice app must use in egypt to make voice control
Thomas_Rohde
Sisko
2179
Hi AmrMustaffa,
Kind regards
Thomas
thien_daotho_mi
Crewman thien_daotho_mi
Crewman
Posted: ‎2022-03-05 12:35 AM
2169
Hi, Does Voice Control is availble in Viet Nam ? Homelynk and Spacelynk ? Thank, Thien Dao
FZetina
Commander
Posted: ‎2022-03-07 12:03 PM
2161
Hello
No, it's not open in Vietnam at this moment.
Once new countries would be added we will communicate it.
Fernando Zetina
thien_daotho_mi
Crewman
Posted: ‎2022-03-08 08:28 PM
2158
Thanks, I have a question about Spacelynk. The Firmware 2.5, I can control by 3rd App ( Iridium Mobile), But when i Update to firmware 2.6, I can't control by 3rd App only control by Spacelynk UI. How can i resolve this issue to control by 3rd app.
Thien Dao
Erwin-vd-Zwart
Janeway
Posted: ‎2022-03-08 10:36 PM . Last Modified: ‎2022-03-08 10:38 PM
2154
With this little info it’s impossible to
answer, how is Iridium communicating with the controller, what protocol is used? Do you have more info about this issue, is the initial connection possible, is control possible, is feedback received etcetera, give us as much info as you can to be able to assist you,
Next to that have you asked Iridium already as it could also be something like an issue with an older TLS in their app or anything in that order…
thien_daotho_mi
Crewman
Posted: ‎2022-03-08 10:47 PM
2151
I use iridium mobile via IP and Port 3671
Erwin-vd-Zwart
Janeway
Posted: ‎2022-03-08 11:11 PM
2148
Are you connecting locally or over public internet? I guess public IP…
thien_daotho_mi
Crewman
Posted: ‎2022-03-08 11:47 PM
2144
I had tried both of them. I can't control it.
Maybe, I have to downgrade and try it again
Erwin-vd-Zwart
Janeway
Posted: ‎2022-03-09 12:01 AM . Last Modified: ‎2022-03-09 12:02 AM
2142
Well, the only thing i can think of that is causing the issue is that we have made a change in the FW due to cyber security, we don't allow external IP adresses to connect to port 3671.
Any IP address that is not in a RFC 1918 private class A, B or C range is blocked to communicate with KNX IP.
Private IP addresses do not exist on the internet so this way you know all communication is originating from the local network.
Is your local network in the correct private IP range?
Class A: 10.0.0.0 - 10.255.255.255
Class B: 172.16.0.0 - 172.31.255.255
Class C: 192.168.0.0- 192.168.255.255
thien_daotho_mi
Crewman
Posted: ‎2022-03-09 01:06 AM
2137
Of course, My private IP is : 192.168.1.117 in the IP range Class C. I will try it again.
How can I allow external IP adresses to connect to port 3671
Erwin-vd-Zwart
Janeway
Posted: ‎2022-03-09 02:05 AM . Last Modified: ‎2022-03-09 02:08 AM
With FW 2.6.x or higher you can't as it is labeled as unsecure and our Cybersecurity department has forced us to close it due to that, the only way to connect from remote locations is via a secure connection like VPN.
Keep in mind that hackers are very active at this moment to scan for open 3671 ports (on any KNX installation regardless the brand/manufacturer) and they delete your programming remotely and enable the BCU protection with a unknown password so your device is bricked if that happens, so i strongly recommand to use save connection methods.
