WISER LINK EER31600
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • WISER LINK EER31600
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
domotiqa
Lt. Commander domotiqa
Lt. Commander
Posted: ‎2018-07-11 12:06 AM . Last Modified: ‎2024-07-14 11:50 PM
1335
WISER LINK EER31600
Looks like exist an application note to connect WISER LINK EER31600 or EER31800 + EER39000 5ti to Homelynk/Spacelynk.
Do you have more information ?
Smarthome & Smartbuilding Expert
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Tags (4)
  • homelynk
  • knx
  • spacelynk
  • wiser link
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2018-09-14 12:28 AM
1325
Hope it would be .. maybe via API?
domotiqa
Lt. Commander
Posted: ‎2018-09-16 10:47 PM
1323
looks like these scripts are working but for old version. Not the new one Smiley Frustrated
domotiqa
Lt. Commander
Posted: ‎2018-09-16 10:48 PM . Last Modified: ‎2018-09-16 10:49 PM
nb_compt = 6
DEBUG = true
require('user.WiserLinkIP')
--[[ Description du nom des usages
Hot_Water = Eau Chaude Sanitaire
Cooling = Refroidissement
Heating = Chauffage
Sockets = Prises
Others = Autres
Electricity_Meter = Total issu du TIC
ADD_IP="192.168.1.11" -- Adresse IP du module Wiser Link IP
PORT=80 --Précision d'un numero de port si NAT sinon laisser 80
LOGIN="admin"--Login
PASS="admin"--Mot de passe
if not my_wiser then
  my_wiser=WiserLinkIP.new(ADD_IP..":"..PORT,LOGIN,PASS)
end
-- Récupération des données depuis le module Wiser Link IP
-- Le rafraichissment est basé sur le temps de cycle du présent script
my_wiser:fetchDatas()
--Rafraichissment des valeurs sur KNX/IP
--log(my_wiser)
-- UPDATE KNX VARIABLES
-- Energies
grp.update('6/0/1', my_wiser.Energy_Heating) 	--Chauffage
grp.update('6/0/2', my_wiser.Energy_Sockets) 	--Prises
grp.update('6/0/3', my_wiser.Energy_Electricity_Meter) --Total
grp.update('6/0/4', my_wiser.Energy_Hot_Water) 	--Eau Chaude
grp.update('6/0/5', my_wiser.Energy_Others) 	--Autre
grp.update('6/0/6', my_wiser.Energy_Cooling) 	--Eau Froide
-- Puissances
--grp.update('6/1/0',my_wiser.Power_Sockets)
--grp.update('8/2/2',my_wiser.Power_Hot_Water)
--grp.update('8/2/3',my_wiser.Power_Heating)
--grp.update('8/2/4',my_wiser.Power_Cooling)
--grp.update('8/2/5',my_wiser.Power_Electricity_Meter)
--grp.update('8/2/6',my_wiser.Power_Others)
-- ******************************************** -- -- SCHNEIDER ELECTRIC -- -- -- -- Author : Valentin THOMAS -- -- Version : 1.0 -- -- Update Date : 17/10/2017 -- -- Name : WISER_LINK.lua -- -- -- -- ******************************************** -- WISER_LINK = function () local self = {script={}} local debug = false local history = false local json = require('json') local http = require("socket.http") -- ------------------------------------------------------------------- --- This function -- @param (none) -- -- @return (none) function round(nb) i,f=math.modf(nb) return i+(math.ceil(f/0.0625)*0.0625) end -- ------------------------------------------------------------------- --- This function -- @param (none) -- -- @return (none) function self.getData(_ip, _login, _password) local wiser_data = {} local datas, http_code, header, err = http.request("http://".._login..":".._password.."@".._ip.."/vesta/UsageMeter") --Si le code HTTP de la réponse est 200 if http_code == 200 then if not datas then error('Cannot fetch data at : '..ip_address) else local datas=json.decode(datas) for index,usage in pairs (datas.UsageMeterList)do usage_name=string.gsub(usage.Type," ","_")--Remplacement de l'espace par un underscore wiser_data["Power_"..usage_name]=round(usage.Power) wiser_data["Energy_"..usage_name]=round(usage.EnergyConsumed) end end else msg=string.format("Error in HTTP request, code:%s, Message:%s",http_code,err) error(msg) log(msg) alert(msg) end end -- ------------------------------------------------------------------- --- This function -- @param (none) -- -- @return (none) function self.script.event(event, _params) end -- ------------------------------------------------------------------- --- This function -- @param (none) -- -- @return (none) function self.script.cycle( _params ) end -- ------------------------------------------------------------------- --- This function -- @param (none) -- -- @return (none) function self.script.scheduler( _params ) end return self end class_var = WISER_LINK() return class_var -- CODE POUR SCRIPTS CLIENT --[[ WISER_LINK = require('user.WISER_LINK') params = { tag_name = 'record', -- tag to add to each knx object to record records_delay = 1, -- delay between 2 records in minutes records_limit = 50000, -- limit of the sql table (adviced 50 000 - 10% de la mémoire) export_delay = 60, -- delay between 2 exports on usb key in minutes export_value_separator = ';', -- name of the export file on the usb key export_line_separator = '\r\n', -- name of the export file on the usb key export_file_name = 'log.csv' -- name of the export file on the usb key } ]]--
