Using LSS100300 as ETS interface
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Using LSS100300 as ETS interface
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-05-13 07:14 AM
1470
Hello Dears,
Could we use the LSS100300 as ETS interface for individual address and application download
Best Regards,
  • SpaceLogic devices
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2025-05-14 12:48 AM
1
1420
I still have a couple of minutes.
I have found an old conversation in which I was reporting exactly your error message.
Enabling both features, routing and tunneling the issue was solved. But, frankly speaking, it was a 2y old conversation.
Maybe something has changed in between
Replies 8
Lt. Commander
Posted: ‎2025-05-13 09:09 PM
Yes Sir!
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-05-13 10:30 PM . Last Modified: ‎2025-05-13 11:34 PM
Thank you  @Cristiano_Carli_Ballola
I got error when trying to add it as interface, note that KNX IP Tunneling is active on LSS100300.
What could be wrong?
Best Regards,
Lt. Commander
Posted: ‎2025-05-13 11:57 PM . Last Modified: ‎2025-05-13 11:59 PM
1424
Hi!
I’m currently at the airport; that’s the reason for the super fast answer, sorry for that.
As long as I remember, I have handled the KNX settings within the Gateway.
If I remember correctly, You have to enable the routing feature because it is somehow connected to with the tunnelling feature
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-05-14 12:33 AM
Thanks for the quick response, I appreciate it.
I already enabled the routing feature, but unfortunately, it didn’t work.
Safe travels and thanks again.
Best Regards,
Lt. Commander
1
1421
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-05-14 01:00 AM
Thanks @Cristiano_Carli_Ballola
the issue was in the Multicast IP, some one change it by mistake.
appreciate your time, hope you a good time.
Best Regards,
Lt. Commander
Posted: ‎2025-05-14 11:28 AM
Hi @IC_Systems
glad to hear that you have solved it.
esteve_budia
Lieutenant esteve_budia Lieutenant
Lieutenant
Posted: ‎2025-05-15 11:43 PM
I would even recommend to check the ACK allways to avoid repetitions .. on all installations, etc, ...
