Universal Dimmer Master 2 channel MTN6710-0102 dimmer out put 0% = 3,4VAC
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Universal Dimmer Master 2 channel MTN6710-0102 dimmer out put 0% = 3,4VAC
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Theodoros
Lieutenant JG Theodoros
Lieutenant JG
Posted: ‎2025-03-11 09:44 PM . Last Modified: ‎2025-03-14 11:03 AM
415
Hi everyone, is there a specific document about the minimum voltage the Universal Dimmer can get ?
Currently i T&C KNX system and the client they asked why the dim value 0% (on EBO interface) but the voltage output not get to 0 VAC.
In ETS the minimum can not be 0%, its need atleast 1%.
  • Documents
  • SpaceLYnk
  • Wiser for KNX
Thomas_Rohde
Sisko
Posted: ‎2025-03-24 03:31 AM
Hello Theodoros!
Sorry for the late reply first of all!
Regarding your topic ...
To be honest ... I didnt get your point fully.
You cant set the value to "0" because the parameter area describes the "dimming curve" (Switch ON state).
That you can switch or let me say dimm off the channel with 0% you define with the parameter below.
So please help me to understand your topic better.
Kind regards
Thomas
Application Design Engineer
