USB power management on SL
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • USB power management on SL
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Jean-Marc
Crewman Jean-Marc
Crewman
Posted: ‎2025-07-11 06:44 AM
397
Hello everyone,
I have a Lua script reading data from a Linky meter via an FT232 USB-to-serial converter connected to /dev/ttyUSB0.
My script has robust error handling and can detect communication failures, but sometimes the FT232 chip gets "stuck" and a simple USB reset is not sufficient to recover. The chip needs a complete power cycle (5V cut) to restart properly.
Currently I'm using a reset function from user library, but it only does a software USB reset which doesn't cut the 5V power supply.
Question: Is there a way from a Lua script (or system command via os.execute()) to completely cut and restore the 5V power supply to a USB port on the SL?
I've considered:
  • uhubctl (if available on SL)
  • GPIO control (if USB power is GPIO-controlled)
  • SL-specific system commands
Any suggestions or experience with this kind of USB power management on SL?
Thanks in advance!
  • Wiser for KNX
Replies 4
Erwin-vd-Zwart
Janeway
Posted: ‎2025-07-16 11:56 PM
390
@Jean-Marc
You can power cycle USB port like this:
Code:
io.writefile('/dev/usbctrl', 'low')
os.sleep(1)
io.writefile('/dev/usbctrl', 'high')
os.sleep(1)
Make sure that serial port is not open in a script when doing the power cycle. Otherwise the port name might change and script won't work. Also make sure to allow "unsafe scripts" in the general configuration otherwise the io.writefile is not executed.
If this does not work your only option is to fully restart the controller by using os.execute('reboot') but be careful with this, if you loop controller in constant reboot, the only way out of that is a full hardware factory reset, so be sure to have a recent backup before trying this.
Jean-Marc
Crewman Jean-Marc
Crewman
Posted: ‎2025-07-18 06:22 AM
Thanks Erwin,
I already tried the function ('/dev/usb ctrl', 'low') it doesn't work. For now I use the reboot but I don't like this solution at all
 BR
Jean-Marc
Crewman Jean-Marc
Crewman
Posted: ‎2025-07-18 08:06 AM
For those who are interested, here is the solution:
function hardResetUSB()
log("Hard reset USB FT232 - Méthode authorized")
-- Déauthoriser le device USB (coupe la communication)
os.execute('echo "0" > /sys/bus/usb/devices/1-1/authorized')
-- Attendre déconnexion complète
os.execute('sleep 3')
-- Réauthoriser le device USB (reconnecte)
os.execute('echo "1" > /sys/bus/usb/devices/1-1/authorized')
-- Attendre reconnexion et re-création de /dev/ttyUSB0
log("Hard reset USB terminé - FT232 réinitialisé")
end
Erwin-vd-Zwart
Janeway
Posted: ‎2025-07-18 11:39 PM
@Jean-Marc
Always target the source of the issue instead of putting bandages in place..
I would replace the USB dongle for a better one that probably keeps working..
