Switch actuator + current detection - MTN647595
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Switch actuator + current detection - MTN647595
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa174915
sesa174915 Schneider Alumni (Retired)
Posted: ‎2015-10-20 03:05 AM . Last Modified: ‎2024-07-14 11:57 PM
517
We found that the switch actuator resets the energy consumption object (object 13 for channel 1)
once the value reaches +/-600kWh. The limit value however is set at 50000kWh in the parameters.
The Energy limit value reached object is never activated (object 14 for channel 1).
In attachment there's a snapshot of the parameter settings.
Kind regards,
Hannes
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Heribert_Dölger
Commander
Posted: ‎2015-10-23 03:56 AM
Hello Hannes
I checked the data base and found that all group objects for energy consumption (objects 13, 32, 51 and 70 for all 4 channels) are linked with group address 0/7/3 "ALLE TOTAL VERBRUIK RESETTEN". This group address is not linked to any other device except the switch actuators with current detection.
Is it possible that there is a device in the network that does not appear in the ETS project data base but executing a reset of the counter (for example HomeLYnk)? As the "write" flag of this group object is activated it would be possible that i.e. HomeLYnk is resetting the counter for energy consumption with the help of this group object.
This might explain why the Counter Limit of 50000 kWh is never reached.
Best regards
Heribert
