Hello Dears,
I have MTN649212 Switch actuator, its stop responding, I see the run led off and the programming led blinking and didnt stop when press on the programming button!
how could solve this issue?
Hello IC_Systems,
if the topic is still valid ... please try the following:
1. Disconnect the device from KNX.
2. Press the programming button and keep it pressed
3. Connect KNX again while keeping the button pressed
4. After a few seconds you can release the button and the device should perform a factory reset.
Please let me know if it helped.
What about the "manual" LED status? Is it fixed or blinking red or totally off?
Did you try making a full download of the device (Physical Address + Application)?
The device was already have application and individual address.
while after the issue, I couldnt download any of (physical address or Application) while the programming led keep pinking, programming button didnt change anything
Dears,
How to do a factory reset? I would give it a try if possible.
Hello IC_Systems,
