Suggestions MTN6194-6010
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Suggestions MTN6194-6010
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
DagEliasSordal
DagEliasSordal
Cadet
Posted: ‎2025-09-19 05:41 AM
6
731
I have played a bit with the new wall switch/panel MTN6194-6010 and I think it is a very promising product.
The buttons are good and responsive, a bit small text on the screen but nicely readable.
The "only" thing I miss is being able to visualize the values on the screen.The first project I plan to use this on is a room where there is downlight and staircase lighting (cinema hall).The switch is in another room, so it would have been very good to be able to see the status of % light on the panel.
Is it possible to get this with a firmware update or is it possible that this will come in the next version?
  • Feedback
  • SpaceLogic devices
Replies 6
Mazen
Crewman Mazen Crewman
Crewman
Posted: ‎2025-09-29 11:05 PM
We're very glad to hear the positive feedback regarding our product, and thank you very much for your suggestion. You are right - currently we do not support seeing the status of % Light during dimming. Reason for that is that this device is usually used in the room as a direct Room Controller.
It's currently not planned in the coming version, but we will check and do our best to include it based on your good feedback!
Thanks a lot for your suggestion.
Mazen
domotiqa
Lt. Commander domotiqa
Lt. Commander
Posted: ‎2025-09-30 09:49 PM
643
Maybe use color change ???
I have another problem on this device.
for our customer, they have a bigger problem. they want device screen off !
Problem:
- click on a buton don't do action of the buton press. they need to click twice. Once to wakeup the device, then second press to perform action.
- if we select wakeup by movment detection, the detection is not very sensitiv. lots of times, the customer explain, device don't wake up
We report this in the past without issue fix.
An easy one should be to add option to perform direct action on press.
I did lots of test on this device without success.
Smarthome & Smartbuilding Expert
Mazen
Crewman
Posted: ‎2025-10-02 03:36 AM
For this we are well aware about and is already part of our upgrades in the next upcoming version. Customer will have the option of clicking ONCE without clicking twice to activate a feature. This is mostly in residential projects where a customer knows his buttons very well by heart.
Thanks for your feedback!
Mazen
domotiqa
Lt. Commander
Posted: ‎2025-10-09 06:23 AM
great !! it is true in residential they know their buton and press without looking on it !
ivan-kirilov
Ensign ivan-kirilov
Ensign
Posted: ‎2025-10-10 01:40 AM
@Mazen , do you plan on allowing us to upload a custom icons? Is it event technically possible? I started to use this product a lot in our recent projects and find them really good, as I'm not a fan of using touchscreens for light controls, but find displays useful. I'm personally fan of icons and would like to have some freedom in uploading own set of icons to use.
Also, I have a problem with aligning "Middle field display" icons/text when using universal button as 1-gang or 2-gang. Middle field icon/text don’t align with the buttons and doesn't look really good.
Also, I find the text of thermostat function (Middle field) really small. It would be really useful if you allow us to change it - even with 2-3 predefined font sizes, not freely.
Mazen
Crewman
Posted: ‎2025-10-20 01:52 AM
Hello Ivan,
Yes we plan on allowing that, and yes it is technically possible. We would like to allow that via a DCA in ETS. It can be useful for you in projects such as hotels or offices or brand projects which have their own icons. Or in case we don't have the icon you wish.
For the alignment and thermostat function, we also plan on fixing both.
I cannot give a timeline for the above as of yet, and we're still in the planning phase, but know these are on the list 🙂
Best Regards,
Mazen
