Hello team
We have created an script on spacelynk to control Toilet light.. Using inputs from 2 motion sensors and 1 push-button.
We have noticed the there is an delay in script execution even the telegram is received from sensors immediately with no delays.... this delay defer each time (some time an 10 sec.. Some time it reachs to 1 minutes delay)
How we can solve this issue?
Thanks in advance.
Hello @Thomas_Rohde
Thanks for your response & apologize for my late replay.
the issue was solved when I used ( while ) script instead of ( If (OR) ) script.
Hello Kais_Aljundi,
can you please share some more informations please:
HW-Version:
FW-Version:
CPU-Load:
Project-Backup (if possible as private message)
Script which causes the trouble (if project backup not possible)
Hello @Thomas_Rohde
Hello Kais_Aljundi,
many THANKS for the clarification/feedback!
Hola Tomas;
No se si puedes ayudarme soy nuevo en estos temas de BMS, quisiera saber si se puede cambiar el rango de las horas de los canales horarios que tengo creados en una Spacelynk, pero quiero cambiar ese rango de horas desde el EBO sin tener necesidad de entrar en la Spacelynk, actualmente tengo dos canales horarios uno en el EBO y otro en la Spacelynk tengo que estar haciendo doble trabajo.
Mil Gracias ojala puedas ayudarme y disculpame!
Unfortunately BACnet scheduler objects are not supported by all models LSS100x00, so what you want is not possible.
Only thing you can do is create a schedule on the system where you want to manage the time period(s), and link the analog/binary output of the scheduler to a BACnet object to control the loads in the second system.
