Spacelynk as IProuter & TP control
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Spacelynk as IProuter & TP control
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
vicbac
Ensign vicbac
Ensign
Posted: ‎2024-01-24 08:12 AM . Last Modified: ‎2024-07-14 11:41 PM
1615
Hi.
Is it possible to have Spacelynk setup as IP router on KNX between 2 KNX lines, and also act as control interface and visualisation?
In the KNX settings I have to choose mode to IP-Router and then the TP-UART doesnt write on KNX buss anymore right?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
PetrMares
Commander PetrMares Commander
Commander
Posted: ‎2024-01-25 01:29 AM
1607
yes. spaceLYnk can act as a KNX IP router. Filtering tables must be properly set.
Replies 4
PetrMares
Commander
1608
vicbac
Ensign vicbac
Ensign
Posted: ‎2024-01-25 01:47 AM
Hi.
Yes but can it at the same time act as visualisation server with the possibility to write commands to KNX TP? Or do I have to have a seperate KNX/IP Router in this case?
vicbac
Ensign vicbac
Ensign
Posted: ‎2024-01-25 04:37 AM
1588
Hi.
But can it act as a IP router and in the same installation act as a visualisation server and be able to write telegrams on KNX TP from visu widgets?
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2024-01-26 01:12 AM
As said before, SL is a native Controller with Webserver AND KNX/IP functionality.
What you have to do is properly set the filter table in both direction, TP>Ip and IP>TP.
You can do that directly from the KNX object view or from the KNX connection settings
