Spacelynk: How to export data from trend logs to a .xls file?
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Spacelynk: How to export data from trend logs to a .xls file?
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Posted: ‎2016-08-29 07:55 AM . Last Modified: ‎2024-07-14 11:54 PM
1057
I have a energy counter and i would like to save data during a month and then export everything to .xls format and send by e-mail. can anyone help me please
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Thomas_Rohde
Sisko
Posted: ‎2016-08-31 11:42 PM
Hi Pedro, attached you will find an updated version of a script which fits to the new internal SW and has now a clear structure in terms of script area where you need to make your adaptations and the other which doesnt need to be changed.
Kind regards
Thomas Rohde
--** Email trendlog data as CSV attachment created by Erwin van der Zwart **--
--************ For HL from FW 1.5 and SL from FW 1.2 with NGINX ************--
--*************************** Start of parameters **************************--
--Gmail (smtp) username !IMPORTANT!
user = 'YOUR EMAIL ADRESS'
--Gmail (smtp) password !IMPORTANT!
password = 'YOUR PASSWORD'
--Sender for e-mail
from = '<' .. user .. '>'
alias_from = 'YOUR ALIAS'
--Recipient for e-mail
to = '<receiver@domain.com>'
alias_to = 'receiver'
--Subject for e-mail
subjectpart1 = 'Trend export file'
subjectpart2 = 'automaticly send by homeLYnk'
--Message on bottom of email (will only be showed when client don't understand attachment)
epilogue = 'End of message'
--Set export mode (selected trend(s) or all trends)
export_all = false
--Set trend names if not all trends need to be exported (only used when export_all = false)
trendnames = {
  "Total Electric Usage",
  "Total Water Usage",
  "Total Gas Usage",
--**************************** End of parameters ***************************--
--****************** DON'T CHANGE ANYTHING UNDER THIS LINE *****************--
require('trends')
-- Get all trend names from DB
trends_table = db:getall('SELECT name FROM trends ORDER BY name DESC')
-- Check if all trends or selection neeed to be exported
if export_all == false then
  -- Loop through trends_table
  i = 1
    for _, trend_names in ipairs(trends_table) do
    delete_from_table = true
    -- Loop through trendnames
    for _, trendname in ipairs(trendnames) do
      if trendname == trend_names.name then
            delete_from_table = false
      end
    end
    if delete_from_table == true then
      table.remove(trends_table, i)
      end
      i = i + 1
  end
end
-- Check if the is at least 1 trend to be exported
if #trends_table < 1 then
  log("No trends available, Could not export trends")
  return
end
-- csv buffer
buffer = {}
-- Add to buffer
table.insert(buffer, '"This file contains the export data of ' .. #trends_table .. ' trend(s) and is automaticly created on ' .. os.date("%A",os.time()) .. ' ' .. os.date("%d-%m-%y at %H:%M") .. '"')
-- Add empty line
table.insert(buffer, '""')
-- months
local months = { "Januari", "Februari", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December" }
  -- Grab trend name from DB table
  trend_name = trend_names.name
  -- Add to buffer
  table.insert(buffer, '"##### START OF TREND ' .. _ .. ': ' .. trend_name .. ' #####"')
  -- Add empty line
  -- Get current timestamp
  timestamp = os.time()
  now = os.date('*t', timestamp)
  -- get data for the past year
    dates = {}
  dates['start'] = now
  if dates['start'].month == 1 then
      dates['start'].month = 12
    dates['start'].year = dates['start'].year - 1
  else
    dates['start'].month = dates['start'].month - 1
  end
  dates['end'] = os.date('*t')
  -- Set resolution to dayly data
  resolution = 86400
  -- Get last month for data by each days in this month
  trenddatamonth = trends.fetch(trend_name, dates, resolution)
  -- Get last month total avarage data
  trenddatamonthavg = trends.fetchone(trend_name, dates, resolution)
  -- Add to buffer
  table.insert(buffer, '"Export of the average usage of the month ' .. months[dates['start'].month] .. ' from trend ' .. trend_name .. '"')
  -- Add empty line
  -- Add header
  table.insert(buffer, '"Start date","End Date","Average month value"')
  -- Add to buffer
  table.insert(buffer, '"01-' .. string.format("%02d", dates['start'].month) .. "-" .. dates['start'].year .. '","' .. #trenddatamonth .. '-' .. string.format("%02d", dates['start'].month) .. "-" .. dates['start'].year .. '","' .. trenddatamonthavg .. '"')
  -- Add empty line
  -- Add to buffer
  table.insert(buffer, '"Detailed export of the daily usage of the month ' .. months[dates['start'].month] .. ' from trend ' .. trend_name .. '"')
  -- Add empty line
  -- Add header
  table.insert(buffer, '"Weekday","Date","Average day value"')
  for _, row in ipairs(trenddatamonth) do
    stamp = dates['start'].year .. '-' .. dates['start'].month .. '-' .. string.format("%02d", _)
        local y, m, d = stamp:match("(%d+)%-(%d+)%-(%d+)")
        local t = { year = y, month = m, day = d}
    -- format csv row
    csv = string.format('%q,%q,%q', os.date("%A",os.time(t)), "" .. string.format("%02d", _) .. "-" .. string.format("%02d", dates['start'].month) .. "-" .. dates['start'].year, row)
    -- add to buffer
    table.insert(buffer, csv)
  end
  -- Add empty line
  -- Add header
  table.insert(buffer, '"##### END OF TREND ' .. _ .. ': ' .. trend_name .. ' #####"')
  -- Add empty line
end
--Create table to include mail settings
local settings = {
    from = from,
    rcpt = to,
    user = user,
    password = password,
    server = 'smtp.gmail.com',
    port = 465,
    secure = 'sslv23',
--Create attachment inside FTP server
src = 'Trend Export '.. os.date('%Y-%m-%d %H#%M#%S') .. '.csv'
dst = '/home/ftp/' .. src
io.writefile(dst, buffer)
--Create subject
subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2
--Load required modules to send email with attachment
local smtp = require("socket.smtp")
local mime = require("mime")
local ltn12 = require("ltn12")
--Create e-mail header
settings.source = smtp.message{
headers = {
          from = '' .. alias_from .. ' ' .. from .. '',
          to = '' .. alias_to .. ' ' .. to .. '',
          subject = subject
--Load attachment inside body
body = {
preamble = "",
[1] = {
        headers = {
           ["content-type"] = 'text/plain',
           ["content-disposition"] = 'attachment; filename="'..src..'"',
           ["content-description"] = '.. src ..',
           ["content-transfer-encoding"] = "BASE64",
        body = ltn12.source.chain(
          ltn12.source.file(io.open(dst, "rb")),
          ltn12.filter.chain(
          mime.encode("base64"),
          mime.wrap()
      epilogue = epilogue
--Send the email
r, e = smtp.send(settings)
--Create alert when sending gives an error with error message
if (e) then
  log (e)
  log (r)
  alert("Could not send email: ", e, "\n")
end
--Delete created backup file from ftp folder inside HL
os.remove(dst)
Kind regards
Thomas
Application Design Engineer
Replies 6
Benji
Administrator Benji Administrator
Posted: ‎2016-08-30 01:31 AM
967
For your convenience, in the future please place your question in the corresponding sub community as more people will see it there. This question had been placed in "Community Help", and only people following this sub Community will get notified. You find the sub communities in the top left part. Click "Communities" and then select the area your question is about.
I've moved this question for you.
Thomas_Rohde
Sisko
Posted: ‎2016-08-30 06:07 AM
Hi Benjamin, thanks a lot for placing this topic into the right section!
Kind regards
Thomas
Thomas_Rohde
Sisko
Posted: ‎2016-08-30 06:14 AM
967
Hi Pedro, where are you struggling in detail?
- Are you able to sent an email in general?
     => if the answer is no please check out this application-note first AN011_SL - Email, SMS and FTP in spaceLYnk
     => if the answer is yes than I will work with you on a script which realizes the monthly trend-report.
Please let me know.
Kind regards
Thomas
Kind regards
Thomas
Thomas_Rohde
Sisko
Posted: ‎2016-08-31 05:20 AM . Last Modified: ‎2022-10-18 10:32 PM
Hi Pedro,
I found within the community here already an example to store all scripts on regular base to a ftp. Means the script needs to be updated.
With the following link you will find script for all trends:
https://community.se.com/message/79811#79811
With the following link you will find script for a single trend:
https://community.se.com/message/79812#79812
Please let me know if this is helpful for you and you can adapt the script to sending an email by yourself.
Otherwise we will go ahead ;o)
Kind regards
Thomas
Kind regards
Thomas
Thomas_Rohde
Sisko
Kind regards
Thomas Rohde
--Sender for e-mail
export_all = false
trendnames = {
  "Total Gas Usage",
require('trends')
  i = 1
      end
    end
      end
      i = i + 1
  end
end
  return
end
-- csv buffer
buffer = {}
-- Add to buffer
-- Add empty line
-- months
  -- Add to buffer
  -- Add empty line
    dates = {}
  else
  end
  resolution = 86400
  -- Add to buffer
  -- Add empty line
  -- Add header
  -- Add to buffer
  -- Add empty line
  -- Add to buffer
  -- Add empty line
  -- Add header
    -- format csv row
    -- add to buffer
  end
  -- Add empty line
  -- Add header
  -- Add empty line
end
local settings = {
    from = from,
    rcpt = to,
    user = user,
    port = 465,
    secure = 'sslv23',
--Create subject
headers = {
          subject = subject
body = {
preamble = "",
[1] = {
        headers = {
          ltn12.filter.chain(
          mime.wrap()
      epilogue = epilogue
--Send the email
if (e) then
  log (e)
  log (r)
end
os.remove(dst)
Kind regards
Thomas
Thomas_Rohde
Sisko
Posted: ‎2016-10-25 10:49 PM
Hi Pedro,
is this topic solved or do you need still support?
In case this topic is answered please mark it accordingly
so that we can get a better view on which kind of topics are really still open.
Thanks a lot for your understanding and support.
Kind regards
Thomas
Kind regards
Thomas
