Posted: โ2015-02-06 02:11 AM . Last Modified: โ2024-07-15 12:03 AM
I was wondering if somebody already tested the AN for sonos integration into KNX via homeLYnk. Any experience with
controlling internet radio on Sonos via homeLYnk ?
I might propose this in a project but haven't had the chance to test it in a real life situation.
Kind regards,
Hannes
Hello Hannes,
there is an application note for this topic:
There is plenty of other application note documents:
Regards
Tomas
Hello Tomas,
I know there is an application note but is was wondering if anyone has tested it in real life with Internet radio control.
Kind regards,
Hannes
Posted: โ2015-02-06 02:41 AM
I tested this solution a month ago. Everything worked quite good. I added volume slider to this solution (additional object and a few lines of script) to make full integration of sonos with KNX.
The only problem might be quite large CPU usage.
Posted: โ2015-02-06 02:45 AM
There is no difference if you are connected to the homeLYnk via WiFi or via VPN.
Sorry Hannes,
I read your question too much in hurry ๐
I will ask author of the AN to give you the feedback.
Tomas
Hello Hannes,
You could find all available Application Notes relating to homeLynk / spaceLYnk controllers here: System design/Architecture
Youโve reached the end of your document
