Run Script when Plan opened
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Run Script when Plan opened
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-11-26 12:46 AM . Last Modified: ‎2024-07-14 11:47 PM
1349
Hello Everyone
Is it possible to run a script when a specific plan opens?
I have a plan with some results to show, but instead of using the resident script, I think to use an event-based script that runs when the plan opens.
How I can do this
any idea?
Best Regards,
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Scripts
  • SpaceLYnk
Erwin-vd-Zwart
Janeway
Posted: ‎2020-11-26 01:05 AM . Last Modified: ‎2020-11-26 01:06 AM
11
1346
You can do that with custom Javascript
$(function(){
   $('body').on('showplan', function(e, id) {
      if(id == 1){
         grp.write('1/0/0', true);
Attach your script to 1/0/0 as event based
BR,
Erwin
Replies 12
Erwin-vd-Zwart
Janeway
11
1347
$(function(){
      if(id == 1){
BR,
Erwin
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-11-26 01:44 AM
1343
and how can I use this javascript in SL?
@Erwin-vd-Zwart
Regards
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2020-11-26 01:48 AM
1341
Goto Configurator -> Scripting -> Tools -> Edit Custom JavaScript and past the code in there, reload the browser so the client gets the JS loaded.
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-11-26 01:58 AM
1338
Thank you  @Erwin-vd-Zwart
Does this Script run for any plan?
I past the script there but the address 0/0/1 didn't change when I open a plan
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2020-11-26 02:01 AM
1336
No, current sample is plan ID 1   if(id == 1), change 1 to your actual plan where you want to activate the LUA script from
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-11-26 02:05 AM
Worked Perfect.
Thanks to @Erwin-vd-Zwart
SL is a very amazing device, I like it
Best Regards,
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-12-23 02:17 AM
1319
hello @Erwin-vd-Zwart
IF I want to use this script for Widgets what should I change?
I try: $('body').on('showwidget', function(e, id) {
but seems not right.
regards
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2020-12-23 02:30 AM
4
1316
There is no build-in event for detecting an open widget, but you can use this to achieve what you want:
$(function(){
var OutputAddr = '32/1/1'
var OpenWidget = 0;
setInterval(function() {
var WidgetNumber = 0;
$('.layer-widget').each(function( index, element ) {
if ( $(this).is(':visible') == true) {
fields = $(this)[0].id.split(/-/);
WidgetNumber = Number(fields[1]);
if (WidgetNumber > 0 && OpenWidget != WidgetNumber){
OpenWidget = WidgetNumber;
grp.update(OutputAddr, WidgetNumber);
//console.log(WidgetNumber);
if (WidgetNumber == 0 && OpenWidget != WidgetNumber){
}, 1000);
This writes the widget number to an object, you can add a event script to this object and add a LUA script like this:
if event.getvalue() == 3 then -- run when widget 3 is open
   -- do your action
end
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2020-12-23 04:05 AM . Last Modified: ‎2020-12-23 04:06 AM
1313
thanks @Erwin-vd-Zwart
perfect 🙂
This Script gives me the Widget ID when it's Open and 0 when closed Right?
I should only enter the address
regards,
Best Regards,
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2022-12-08 01:41 AM
1292
Hello @Erwin-vd-Zwart
I've noticed that both JS stop working after Firmware update.
now I am using the last Version 2.8.0
Could you help in this
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2022-12-08 02:29 AM
1
1280
@IC_Systems
I just tested both on 2.8.0 and they still work.. Do you have any errors in the console (F12)?
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2022-12-11 12:01 AM
That's right @Erwin-vd-Zwart  there was an error
Best Regards,
