DALI Gateway MTN6725-0003 two application available 7312 and 7308. What to choose? KNX DALI-Gateway Basic REG-K/1/16/64
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • DALI Gateway MTN6725-0003 two application available 7312 and 7308. What to choose? KNX DALI-Gateway Basic REG-K/1/16/64
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2022-11-15 01:14 AM . Last Modified: ‎2024-07-14 11:43 PM
857
Hello
I can't download configuration to DALI Gateway MTN6725-0003 KNX DALI-Gateway Basic REG-K/1/16/64 i get info:
"Memory block entry failed."
"Programming(Appl.): faulty."
I have MTN6725-0003 DALI Gateway. What application to choose? What to check to be able to choose. In download there are two versions available:DALI Gateway Basic applicaion.jpg
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Local App
Tags (2)
  • dali
Heribert_Dölger
Commander
Posted: ‎2022-12-07 05:41 AM
Hello Piotr
There was new application 7312 and DCA released for KNX DALI gateway basic about two years ago. It has enhanced functionality compared to the old one, most important feature is that it now also allows single ECG control (old application only supported the control of groups).
The new application is based on new firmware (0.3.0 and higher). New products from stock are meanwhile equipped with this new firmware.
DALI gateways with new firmware cannot be commissioned with old application, and gateways with old firmware cannot be commissioned with new application.
If you have a new gateway with FW 0.3.x but want to use the old application (ie. for replacement in existing installation) there is a special downgrade firmware (0.2.8 downgrade) that will allow the usage of old application. Only this downgrade version has to be used as it is "unconditional" and will delete all parts of new FW. When upgrading "old" device (FW 0.2.8 or lower) you first have to install FW 0.3.0 as only this version is "unconditional". Other versions are "conditional" and do keep the existing configuration during the FW upgrade.
Heribert_Dölger
Commander
Hello Piotr
