Posted: 2021-10-10 02:51 AM . Last Modified: 2024-07-14 11:45 PM
Hi Team,
Here I have attached a link, which have all details in it.
https://drive.google.com/file/d/13-Pn9YsVWYvQRzTsRE_m1j87z4N3Frpz/view?usp=sharing
We need to integrate our HVACs with our Spacelynk & HomeLynk Devices on KNX.
Please ensure that can we will success to integrate & how can we integrate the same.
We are waiting for your valuable ideas.
Deepak Gupta
Hello @Anonymous user
why not using BMS, and you can integrate SL & HL into BMS
BR,
As this device (Distech Controller) is a BACnet server and the SL or W4K is also a server you have a few options:
1) Use the BACnet client app, however this is limited to a certain number of objects and devices, this raises the question how many devices do you need to integrate and how many objects do you want to use inside each device?
2) If there are multiple devices and a high number of total BACnet objects you probably need a more robust solution, in that scenario you need to use for example an EcoStruxure Building Operation Automation Server as a client to bridge between both servers and bind them here together, here you also have to take into account the number of devices and BACnet points for SL, W4K and AS-P but those are a lot higher then the BACnet client app offers.
Both architectures raises the question how many devices do you need to integrate and how many objects do you want to use inside each device to be able to give a good advice on what you should do and what limits you have to take into account in your architecture.
Another question i have is the PDF is listing a lot of separate components, is this already connected to the Distech controller ?? or do you need to assemble all this devices to a total solution? If that is the case you definitly need a BMS solution as an AS-P with I/O or AS-B or MP-C..
BR,
Erwin
