Reacting on ftp upload
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Reacting on ftp upload
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
baerdo
Crewman baerdo
Crewman
Posted: ‎2025-08-09 03:02 PM
466
Is it possible to react in a script when a file has been uploaded to the spaceLYnk ftp server?
  • Scripts
  • SpaceLYnk
  • Wiser for KNX
Erwin-vd-Zwart
Janeway
Posted: ‎2025-08-27 03:25 AM
1
420
@baerdo
You could use a resident script to read the files in the ftp folder and based on the result create a condition to do something with script..
function scandir(dirname)
  callit = os.tmpname()
  os.execute("ls -a1 "..dirname .. " >"..callit)
  f = io.open(callit,"r")
  rv = f:read("*all")
  f:close()
  os.remove(callit)
  tabby = {}
  local from  = 1
  local delim_from, delim_to = string.find( rv, "\n", from  )
  while delim_from do
    filename = string.trim(string.sub(rv, from , delim_from-1))
    if filename ~= "." and filename ~= ".." then
  table.insert( tabby,  filename)
    end
    from  = delim_to + 1
  end
  return tabby
end
filetable = scandir("/home/ftp/")
if type(filetable) == 'table' then
log("Nr of files = " .. #filetable)
for _,filename in ipairs(filetable) do
  log(filename)
  end
end
baerdo
Crewman baerdo
Crewman
Posted: ‎2025-08-27 04:57 AM
thanks for the code. For me this could be part of a workaround. I think it would be much better to either have a listener with an event or something similar. It would be more user friendly. Or did I miss something like a http listener or a tcp listener? I have not found anything like this. I would like to pass over from a different system a few stati from sensor. I can either do filetransfer or upload over tcp in general or http, mqtt or so.
Erwin-vd-Zwart
Janeway
Posted: ‎2025-08-27 11:03 PM
There is no event available on FTP so your only option is this script.
You could have a tcp listener, MQTT is also available so what do you prefer?
