Push-button Pro T MTN6185
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Push-button Pro T MTN6185
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2021-12-16 07:16 AM . Last Modified: ‎2024-07-14 11:45 PM
912
Hello
1) New Push-button Pro T MTN6185 have mechanical (similarly like in old Push-button Pro ?)  buttons or some new kind capacity/other technology?
2) We don't have build in Temeprature regulator so we must use this button only for temperature sensing or use external temperature regulator?
Also we don't have "devices" label so im labelins as Wiser for KNX
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLogic devices
Thomas_Rohde
Sisko
Posted: ‎2021-12-16 07:47 AM
1
908
Hello Piotr,
ANSWER: It is the same device as before in terms of mechanic and same kind of technology for detection of operation.
The adapted part is the electronic (PCB and added temperature sensor) and the SW of course.
ANSWER: Yes, we use this for temperature sensing but this is a very good feature as you can use it in combination with the new SpaceLogic KNX Valve Drive Controller (MTN6730-0002) which has 6 independent PI temperature controllers.
ANSWER: I do not understand this sentence?! Can you please describe this point more in detail?
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
1
909
Hello Piotr,
Kind regards
Thomas
PiotrJakubczyk
Sisko
Posted: ‎2021-12-17 01:34 AM
Thanks Thomas for very detailed response!
Sorry i didn't make myself clear on "lablel" topic. When you create post in KNX forum you must assign "label" (so im assuming it is important 😉 ) to the post and there are only categories like on this attached screen. But i get my response so thank you!
