One Byte switch button on U.motion to send value to KNX ?
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • One Byte switch button on U.motion to send value to KNX ?
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
sesa99367_bridg
sesa99367_bridg Schneider Alumni (Retired)
Posted: ‎2016-03-03 08:03 PM . Last Modified: ‎2024-07-14 11:56 PM
980
How to build one byte button on U.motion to send value to KNX? Like a scene value send or level value send, using a switch button, the same as KNX panel button?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
Tags (3)
  • one byte
  • send value
  • u.motion
Replies 6
Cristiano_Carli_Ballola
Lt. Commander Cristiano_Carli_Ballola Lt. Commander
Lt. Commander
Posted: ‎2016-03-07 08:13 AM
922
Hello Guangiin Feng,
did You already tried to use the "Scene" funcntion?
In the Configurator, you have to create a "New Scene" and link it to a single Group Address (KNX Object).
Then You have to set the value You want to send and link the Scene to a Room or to a Function page
sesa99367_bridg
Posted: ‎2016-03-07 08:04 PM
Thanks for your reply, CRISTIANO CARLI BALLOLA
Yup, I had already create a Scene, and create a button on Function page, but it can't satisfied end user neither, he wanted to push a button only, not to push 'play' and 'stop' button, so I have no idea, how to create an 1 byte button.
Lt. Commander
Posted: ‎2016-03-08 03:17 AM
3
922
Hello Guangjin Feng,
as 2nd option, you can create a 1bit "Virtual object" and link your 1byte group address as "Active event"
These are some examples.
You can also see how the "scene button" can look like (just play, no stop)
sesa99367_bridg
Posted: ‎2016-03-08 07:02 PM
922
Oh, your suggestion solved my issue, thanks a lot, I think end user will accept it. And it's funny, how can you make scene button like that? Just ‘Play’ not 'Stop', weather we can modify button or there are other ways, including modify button display? Thanks again !
Thomas_Rohde
Sisko
Posted: ‎2016-03-08 11:11 PM
922
to "...how can you make scene button like that? Just ‘Play’ not 'Stop' ..."
First you need to go "EXPERT" mode to have all possible parameter available.
Within this mode you will see the parameter "Stoppable". When you deactivate
the checkbox than the button will be not shown.
Kind regards
Thomas
Application Design Engineer
sesa99367_bridg
Posted: ‎2016-03-09 08:12 PM
Thanks very much Thomas Rohde and CRISTIANO CARLI BALLOLA , thank you for all your help.
