MTN6214-03xx window function
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • MTN6214-03xx window function
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2021-08-18 02:24 AM . Last Modified: ‎2024-07-14 11:46 PM
794
Hello
I have read application description for MTN6214-03 ( doc P6212_562_00_1817_10_EN ) and window functionality (turn off heating cooling when window is open) is described very generally using "Locking object". Can someone explain how to configure MTN6214-03 to have window (energy holdoff) functionality and what additional device will be needed (binary input MTN644492 ?)
Anything that can be interpreted as similar functionality is in Control general/Termination of comfort extension via objects
and then use "Comfort extension input" in group address with  switch object from Binary input?
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Local App
Erwin-vd-Zwart
Janeway
Posted: ‎2021-08-18 02:38 AM . Last Modified: ‎2021-08-18 02:41 AM
3
791
You should use object 45 - Frost/Heat protection
See attached expert training document on page 18
knx-13 room temperature control 02.2011 se.zip
Thomas_Rohde
Sisko
Posted: ‎2021-08-18 02:54 AM . Last Modified: ‎2021-08-18 02:59 AM
Hi!
Erwin is right. You should use the frost heat protection function.
Attached an older picture but still valid.
And YES you can use MTN644492 for it.
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Posted: ‎2021-08-18 06:58 AM
Hi Piotr,
in general it is up to you or your customer requirements.
Of course you can use the "Bell function / Symbol" for it.
Dedicated manual
Kind regards
Thomas
Replies 4
Erwin-vd-Zwart
Janeway
3
792
Thomas_Rohde
Sisko
Hi!
Kind regards
Thomas
PiotrJakubczyk
Sisko
Posted: ‎2021-08-18 03:03 AM
779
Thanks Erwin!
Can i switch on "bell icon" when window is open? Or user should interpret lack of heating/cooling icon as opened window?
Thomas_Rohde
Sisko
Hi Piotr,
Dedicated manual
Kind regards
Thomas
