Legacy Merten ETS files
SpaceLogic KNX Forum
Showing results forΒ
Did you mean:Β
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Legacy Merten ETS files
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_DΓΆlger
Commander Heribert_DΓΆlger Commander
31
Back to SpaceLogic KNX Forum
Me1300
Crewman Me1300
Crewman
Posted: β€Ž2025-01-23 11:49 AM
3130
I have to restart from scratch the home automation of my house (we bought it 10 years ago and nor the installator or the old owner have the project files) but I can't find the device catalog for the actuator/switches to use them in ETS.
So, does anyone have the legacy Merten ETS files for product from years 1999-2001? Like those: 6310 19, 6900 99 (I found this one), 6201xx
Or, maybe should I use similar P/N which are available?
Thank you
  • Other
  • SpaceLogic devices
Thomas_Rohde
Sisko
Posted: β€Ž2025-01-29 12:15 AM
2978
Hello Me1300!
Of course we have it πŸ˜‰
Kind regards
Thomas
Application Design Engineer
6285 Anzeigeeinheit.zip
Replies 12
Thomas_Rohde
Sisko
Posted: β€Ž2025-01-24 02:44 AM
3109
Hello Me1300,
please share with me the complete list of ETS-Application you need.
We will make it work again πŸ˜‰
Kind regards
Thomas
Me1300
Crewman Me1300
Crewman
Posted: β€Ž2025-01-26 04:03 PM
Hello Thomas,
Thank you for your quick answer (I wasn't notified of it πŸ™‚ ).
Until now, I almost found all of the files for the switches but I'm still stuck with the following models:
- Merten 6215 (ARGUS 180 UP) 1304 10 (device=M-000C_A-1304-10)
- Merten 6473 29 (device=M-000C_A-4327-01)
- Merten 6474 29 (device=M-000C_A-4117-01)
- Merten 6472 29 (/device=M-000C_A-4105-01)
I will still need to discover 2 other devices (actuators) but they are in a technical room behind a wardrobe... (I think they are the same as other listed above).
Thank you,
Thomas_Rohde
Sisko
Posted: β€Ž2025-01-26 11:28 PM
3074
Hello Me1300!
Attached you will find the needed files.
Please let me know in case some more applications are needed.
Kind regards
Thomas
647229-00.zip
647329-00.zip
647429.zip
6215xx-00.zip
Me1300
Crewman Me1300
Crewman
Posted: β€Ž2025-01-27 12:09 AM
3059
Hello Thomas,
Thank you for the files, they are working fine for the actuators.
For the 6215, the file only contains version 1304 20 => Different Application Program loaded (project=M-000C_A-1304-20-611C/device=M-000C_A-1304-10).
Do you also have this one?
Big thank you πŸ˜‰
Me1300
Crewman Me1300
Crewman
Posted: β€Ž2025-01-27 01:37 AM
I moved the wardrobe and see that the actuator I thought it was, was not what I expected 😞
=> I also need the following:
- Merten 6374 29 (not sure of the version: 4196 02 or 6011 01)
- Merten 6219/6220 version 2114 03 (thermostat)
I still need to find 1 more which I thought was with the 6374...
Thank you
Thomas_Rohde
Sisko
Posted: β€Ž2025-01-27 01:54 AM
3044
Hello Me1300!
I do not have it as a single ETS-Applikation but you can find it in the complete database attached.
Kind regards
Thomas
M230_TP 1.zip
Me1300
Crewman Me1300
Crewman
Posted: β€Ž2025-01-27 08:54 AM
3024
Thomas,
No problem for the bundle πŸ™‚
I found the last one: Merten 6285  6011 01
And just in case you know it: do you know how I can find which "memory" is mapped to which parameters in the GUI?
For example, I have this message error and must find which memory is mapped to which parameters and which value is used.
Found parameter differences: 2 different byte(s)
at Memory[$01F4]: project=31($1F)/device=29($1D)
at Memory[$01F5]: project=35($23)/device=33($21)
Thank you,
Thomas_Rohde
Sisko
Posted: β€Ž2025-01-28 01:10 AM
3007
Hello Me1300!
Unfortunately we do not have such kind of Memory/Parameter-Setting Overview for all our ETS-Applications.
Is it not faster, as you have all needed ETS-Applications, to simply reprogram the dedicated devices?
Kind regards
Thomas
Me1300
Crewman Me1300
Crewman
Posted: β€Ž2025-01-28 05:09 AM
Hello Thomas,
I think I will go this way (and hope I don't forget something my wife will be angry πŸ˜„ ).
I don't find the ETS files for the last one: Merten 6285 6011 01
Do you have it?
Thank you
Thomas_Rohde
Sisko
2979
Hello Me1300!
Kind regards
Thomas
Me1300
Crewman Me1300
Crewman
Posted: β€Ž2025-02-02 10:55 AM
Hello Thomas,
Thank you for your time and all the files.
I succeeded in reconfigure the devices.
Thomas_J
Thomas_J
Cadet
Posted: β€Ž2025-10-25 04:31 AM
Hello Thomas,
I would need the legacy files Merten 1331 for motions detectors?
Thanks in advance
Β
