LSS100100 Modbus integration with BMS
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • LSS100100 Modbus integration with BMS
Thomas_Rohde
Sisko Thomas_Rohde Sisko
131
Erwin-vd-Zwart
59
Heribert_Dölger
31
FZetina
Commander FZetina Commander
29
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
Ascentrek
Ascentrek
Cadet
Posted: ‎2021-09-05 09:43 AM . Last Modified: ‎2024-07-14 11:46 PM
732
Dear team can we integrate lss100100 to bms via modbus protocol if possible pls confirm process
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Protocols
David_Navratil
Lt. Commander David_Navratil Lt. Commander
Lt. Commander
Posted: ‎2021-09-06 12:35 AM
Hello @Ascentrek,
What BMS device you are about to integrate with LSS100100?
Yes it is possible. LSS100100 supports both Modbus RTU or Modbus IP.
Process is that:
1. You need Modbus profile - what is the definition of the registers from the BMS device what you will be sending/receiving over Modbus
2. If this profile is already available in the LSS100100 list of the profiles you need only to add new device with correct parameters and this profile used.
3. If the profile does not exist you have to define a new one based on the Userguide where is a description of what parameters and how the profile is defined. Also, you can download the already existing profile from the LSS100100 to see the structure and redefine it to your needs.
Regards
David
Ascentrek
Ascentrek
Cadet
Posted: ‎2021-09-05 09:49 AM
How to integrate lss100100 to bms via modbus protocol
David_Navratil
Lt. Commander
Hello @Ascentrek,
Process is that:
Regards
David
