Issue in dimming with SpaceLogic MTN6710-0102
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Issue in dimming with SpaceLogic MTN6710-0102
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
chetan
Crewman chetan Crewman
Crewman
Posted: ‎2023-03-09 09:47 PM . Last Modified: ‎2024-07-14 11:43 PM
1066
We are facing issue with Spacelogic MTN6710-0102 dimmer. System working fine for 3-4 days & then button configuration on MTN627819 keypad changes automatically. Also, in some of the DB’s we get red indication on the dimmers and keypad stops working. Please note that after programming system runs trouble free for 2-3 days. (ETS Version ETS6.0.6)
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Local App
Thomas_Rohde
Sisko
Posted: ‎2023-03-10 12:07 AM
Hello Chetan!
Pretty intersting/strange behaviour 🤔
Just to make sure ... after ETS-Download Dimmer and and PB works as they should.
Means you can dim your lights and switch them on/off via the PB for some days without having the red LED activ on the dimmer.
Then something happens ... the dimmer goes in error mode and the PB looses his configuration.
You download again the ETS-Applications and then it works again for some days?
Is it like this?
Is this cabinet installed within an industrial environment where some heavy machines are working?
Can you please provide more detailed information of the dimmer by the use of the DFU-Tool?
There is a diagnostic functionality included which generates a certain report.
2023-03-10_08h55_55.jpgHere the links to the tool and documentation of the tool in case you do not use it already.
Tool = On this side within the section software
https://www.se.com/ww/en/product/MTN6710-0102/spacelogic-knx-universal-dimmer-master-2-channel/
Documentation = https://download.schneider-electric.com/files?p_Doc_Ref=KNX_DFUtool_SW_EN&p_enDocType=User+guide&p_F...
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
Hello Chetan!
Is it like this?
Kind regards
Thomas
