Econfigure - multitouch and fan actuator missing link
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Econfigure - multitouch and fan actuator missing link
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
domotiqa
Lt. Commander domotiqa
Lt. Commander
Posted: ‎2023-02-01 04:55 AM . Last Modified: ‎2024-07-14 11:43 PM
1363
when linking a multitouch with a fan coil actuator MTN6730-0003. Only one object is mapped  (see screenshot)!!
No fan speed, and also on the multitouch no fan speed page enable.
In my case the thouch need to operate on floor heating system and Fan system.
I was thinking of linking the output heating of the multitouch to both fan and floor heating, and create another page with ON/OFF bun to activate FAN heating and another to activate Floorheating. No way to link a ON/OFF multitouch command to floor heating and/or fan actuator on ETS (maybe to lock object...)
Smarthome & Smartbuilding Expert
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • eConfigure
domotiqa
Lt. Commander
Posted: ‎2023-03-08 02:37 AM
Hi David,
is there a way to have the zip file to put in c:\ProgramData\Schneider Electric\eConfigure\Standalone5\Catalog\Devices\
I have a programmation next week with 20 fan actuator. The house is already programmed with econfigure. I would like to avoid the ETS5 programmation for this.
regards
Replies 5
David_Navratil
Lt. Commander David_Navratil Lt. Commander
Lt. Commander
Posted: ‎2023-02-02 03:59 AM
1355
Are you using eConfigure lite or Expert? I can see you are using ETS5 version.
Can you provide us with Project?
Thank you
David
domotiqa
Lt. Commander
Posted: ‎2023-02-02 04:36 AM . Last Modified: ‎2023-02-02 04:41 AM
Hi David,
econf 1.8.0.11
catalog 1.8.1
I wasn't very well explaining. In fact there is two question.
1/ I just put a multitouch, I put fan actuator, I linked them. I put on topology a spacelogic actuator add assign output, then generate. Only heating value is linked
2/I need to operate on floor heating system and Fan system. My idea was to use the same temp setpoint for both and the customer choose to activate the fan ON/OFF on other page. It s whats looks like the easy way for him (there is 10 fan in the house and everytime a multitouch).
I put you example of what I want to do for the both floorheating and fan. More and more residential customer use the both. I like using Econfigure for residential project (quick), but in these case, I need to create second project on ETS to link value (On/off, lock, Fan speed, mode....)
151-fan.zip
domotiqa
Lt. Commander
Posted: ‎2023-02-13 10:08 PM
any news ? thks
David_Navratil
Lt. Commander
Posted: ‎2023-03-08 01:15 AM
1327
Yes you are completely right, we are missing the Fan coil speed control in the Fancoil actuator. We will address this in near future. Meanwhile, I have tried to find a workaround if we have way how to do it now, but no luck.
Seek this in the next catalog version.
Regards
David
domotiqa
Lt. Commander
Hi David,
regards
