How to flash microSD card AN 09/2018 rev. 1
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • How to flash microSD card AN 09/2018 rev. 1
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2023-11-20 01:46 AM . Last Modified: ‎2024-07-14 11:42 PM
1581
Hi
Trying to execute AN2 (How to flash microSD card) on my W4K (HW. V3.2) RN-2022-W13-0934.
1)Can someone share card image for W4K HW3.2? W4K_HW2_xx_3_xx_recovery.img from AN is not working. Red diode inside W4K is blinking but LED1 is constant off.
2) In AN it is mentioned to format microSD but not explained how. Is my formatting setup ok? (default setup)
Also video link in AN is not working https://youtu.be/jwyTh1LFX_s
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Wiser for KNX
Erwin-vd-Zwart
Janeway
Posted: ‎2023-11-20 11:57 PM
This is the image needed for flashing SD on HW3.2 or lower, works on all HW versions of W4K and SL.
I will ask the team to update the AN's with this file. Make sure to extract the.zip AND the .gz so you have a .img file of around 970Mb that you need to restore on your SD card with Usb Image Tool.
recovery-imx6-1g.img.gz.zip
Erwin-vd-Zwart
Janeway
PiotrJakubczyk
Sisko
Posted: ‎2025-02-27 06:41 AM
Here is upgraded tutorial / application note
source: https://www.se.com/hk/en/download/document/AN2_001/
AN2_001_How_to_flash_microSD_card_W4K_SL.zip
BM_AN_2_001_How_to_flash_microSD_card.pdf
Date: 03 Jun 2024 | Type: Application Notes
Languages: English | Version: 2.3
Document Reference: AN2_001
