GoodWe SemsPortal via Wiser KNX Connection
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • GoodWe SemsPortal via Wiser KNX Connection
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
Ozturker
Ensign Ozturker
Ensign
Posted: ‎2024-07-29 03:47 AM
4
968
If you are trying to get your PV generation information from GoodWe Sems Portal via Wiser KNX please write your questions below this post.
Please make sure your have below information
require('socket.http')
require('ltn12')
require('json')
email = "YOUR EMAIL"
password = "YOUR PASSWORD"
powerstation_id = "YOUR INVERTOR ID"
  • SpaceLYnk
  • Wiser for KNX
Ozturker
Ensign Ozturker
Ensign
Posted: ‎2024-07-31 02:30 AM
2
916
Hi Thomas,
The response is a giant table but here a couple of lines as an example
* table:
 ["backUpVload_S"]
  * number: 6553.5
 ["istr10"]
  * userdata: NULL
 ["battary_work_mode"]
  * number: 0
 ["istr12"]
  * userdata: NULL
 ["pbackup"]
  * number: 0
 ["istr3"]
  * userdata: NULL
 ["dspSvnVersion"]
  * number: 335
 ["istr15"]
  * userdata: NULL
 ["bms_alarm"]
  * number: 4096
 ["pre_hour_lasttotal"]
  * userdata: NULL
 ["bms_discharge_i_max"]
  * number: 1
 ["sn"]
  * string: 95000EHR*******
 ["isbuettey"]
  * bool: true
 ["grid_conn_status"]
  * string: generating_on_grid
 ["backUpPload_T"]
  * number: -1
 ["istr14"]
  * userdata: NULL
 ["total_buy"]
  * number: 471.55
 ["ram"]
  * number: 22
 ["dataloggersn"]
  * string:
 ["genset_etotal"]
  * userdata: NULL
 ["istr16"]
  * number: 0
 ["genset_mode"]
  * userdata: NULL
 ["iac2"]
  * number: 6553.5
 ["eChargeDay"]
  * number: 0
 ["reactive_power"]
  * number: 0
 ["name"]
  * string: GW500***
 ["ezPro_connect_status"]
  * userdata: NULL
 ["backUpIload_S"]
  * number: 6553.5
 ["mtActivepowerR"]
  * number: 2194
 ["istr5"]
  * userdata: NULL
 ["meter_type"]
  * number: 1
Replies 4
Thomas_Rohde
Sisko
Posted: ‎2024-07-30 04:24 AM
Hello Ozturker,
many THANKS for sharing!
Could you please share with the community also the second part (analysing part of the answer from the portal)?
Just to have it complete.
Kind regards
Thomas
Application Design Engineer
Ozturker
Ensign Ozturker
Ensign
2
917
Hi Thomas,
* table:
 ["backUpVload_S"]
  * number: 6553.5
 ["istr10"]
  * userdata: NULL
  * number: 0
 ["istr12"]
  * userdata: NULL
 ["pbackup"]
  * number: 0
 ["istr3"]
  * userdata: NULL
 ["dspSvnVersion"]
  * number: 335
 ["istr15"]
  * userdata: NULL
 ["bms_alarm"]
  * number: 4096
  * userdata: NULL
  * number: 1
 ["sn"]
 ["isbuettey"]
  * bool: true
 ["backUpPload_T"]
  * number: -1
 ["istr14"]
  * userdata: NULL
 ["total_buy"]
  * number: 471.55
 ["ram"]
  * number: 22
 ["dataloggersn"]
  * string:
 ["genset_etotal"]
  * userdata: NULL
 ["istr16"]
  * number: 0
 ["genset_mode"]
  * userdata: NULL
 ["iac2"]
  * number: 6553.5
 ["eChargeDay"]
  * number: 0
 ["reactive_power"]
  * number: 0
 ["name"]
  * string: GW500***
  * userdata: NULL
 ["backUpIload_S"]
  * number: 6553.5
 ["mtActivepowerR"]
  * number: 2194
 ["istr5"]
  * userdata: NULL
 ["meter_type"]
  * number: 1
Thomas_Rohde
Sisko
Posted: ‎2024-07-31 06:33 AM
915
Hello Ozturker,
is this a popular portal in turkey?
Kind regards
Thomas
Ozturker
Ensign Ozturker
Ensign
Posted: ‎2024-07-31 06:55 AM
Hi Thomas,
GoodWe is a big brand in Europe known with high quality inverters. SEMS portal is their platform for users to track and monitor their inverters, generation and consumptions
with right equipment inverters have modbusTCP connection as well
in Turkiye we can check but here in Spain it is famous
Best Regards
Turker
