ETS download Using LAN as backbone and main line
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • ETS download Using LAN as backbone and main line
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2022-03-24 09:02 AM . Last Modified: ‎2024-07-14 11:44 PM
769
Hello
I have a project and used the combination of line couplers and IP/Routers, while all the backbone are IP routers,
could I use the SL as IP tunneling in ETS to download address and application?
and what the SL mode should be, and could I use the IP Routing?
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
Thomas_Rohde
Sisko
Posted: ‎2022-03-25 01:50 AM
765
Hi IC-systems,
yes you can do so. Attached you will find a dedicated picture out of the manual which is linked also.
The dedicated KNX-Connection description starts at page 47.
Here the link to the manual:
https://download.schneider-electric.com/files?p_Doc_Ref=AR1796_EdP_EO&p_enDocType=User+guide&p_File_...
Kind regards
Thomas
Application Design Engineer
Thomas_Rohde
Sisko
766
Hi IC-systems,
Kind regards
Thomas
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2022-03-30 12:37 AM
Thanks @Thomas_Rohde
I will test this in the site and If I need support I will come back.
Best Regards,
