Hello guys. I have KNX/DALI gateway PRO (MTN6725-0101) with firmware version V1.2 and I want to update to V2.0. I have installed DFU tool, I can connect to DALI gateway - but I don't have FW file to update. On webpage there is FW data to download, but it does nothing for update. DFU tool wants me to show him FW archive file on my local disk. And I can't find it anywhere on website... So where can I find FW archive for DALI gateway to update FW from 1.2 to 2.0 ?
Hi GasperP_SI!
Attached you will find some pages which describes the update process in detail.
Just to double check if you really did all necessary steps.
Please keep us updated π
Posted: β2024-04-21 04:50 AM . Last Modified: β2024-04-21 04:52 AM
Thank you for the file. But this is the same file that is on the web page. I have this ZIP file. Inside there are two *.cms files and further folder with JSON file. When I show this folder to DFU tool it says that everthing is up to date and NO update is required. And when I connect my DALI gateway version 1.2 no update is offered. So either this file does not include firmware 2.0 or I'm doing something wrong.
Yes that worked! My problem was that I was trying to find *.FW file for DFU tool.
Of course I was unabe to find it. You need to show/select *.ZIP archive!! I was missing this information.
Then it worked immediately.
Thank you! Issue solved.
Great! Many THANKS for the feedback!!
Hi, some additional question regarding Dali pro upgrading. I installed new device and successfully upgraded to latest FW version (2.1.5), then I took knx.prod file for new version of this device and program it from zero. All is ok.
But, I also have other devices with older FW version and already programmed and used. What to do with existing devices? Simply upgrade them with DFU tool? Latest commissioning DALI plugin version will work with older FW? Do I need to import newest knx.prod file for existing devices and again reprogram them after FW upgrade?
BR,
Alexander
Hello Alexander_Remteks!
I am not sure that I get your point correctly "But, I also have other devices with older FW version and already programmed and used. ".
I guess you mean that you have a project where already DALI-GWs installed and up and running for some time.
It is not mandatory to update the ones which are already working for some time.
Unless you need to use feature which has arrived with latest FW-Updates.
Here, unfortunately not complete, an overview of the cowork of HW-FW, ETS Application and DCAs.
Does it answer your question?
Hi, Thank you, your info totally enough. I will use existing devices with no FW upgrade, all is working as needed.
BR,
Alexander
