DALI GW Verification error
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • DALI GW Verification error
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2023-03-20 01:59 AM . Last Modified: ‎2024-07-14 11:42 PM
1175
Hello Dears,Documents
I have KNX DALI GW  (MTN6725-0001), when download from the DCA I got Verification error Pop up message for few ECGs.
the verification error message was like sending 270 received 1.
but the ECGs respond when turn it on/off.
so does this verification error cause any issue and require attention?
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Protocols
Heribert_Dölger
Commander
Posted: ‎2023-04-06 04:05 AM . Last Modified: ‎2023-04-06 04:57 AM
Hello @IC_Systems
this message appears if the reported device type does not match the planning.
However, the reported value of 63 or 127 is very unusual.
It means the device type could not be read properly, or the answer was 63 or 127 (which doesn't make much sense).
my proposal:
Drag these faulty ECGs back to the right side
Download (programming) so that they are free again.
Right-click in the right tree and select "Initialize ECG" in the context menu. (The ECG is completely reset)
Then start a "post-installation"
The devices should reappear on the right side.
Now move the mouse and check the device type in the tooltip.
Are all ECGs of the same type or is it possible that the faulty ones are from a different manufacturer?
Replies 4
Thomas_Rohde
Sisko
Posted: ‎2023-03-20 04:57 AM
1171
Hello IC_Systems!
to "... I got Verification error Pop up ..."
Can you please share a screenshot of the pop up?
Kind regards
Thomas
Application Design Engineer
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2023-03-20 07:18 AM . Last Modified: ‎2023-03-30 06:50 AM
1
1168
Will share it when I back to the site.
Edit:
Please see attached Screen shoots @Thomas_Rohde
Best Regards,
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2023-04-06 02:41 AM
Hello @Thomas_Rohde
Do you have any update?
is it a serious issue, while the ECGs are working!
Best Regards,
Heribert_Dölger
Commander
Hello @IC_Systems
my proposal:
