DALI GW Comparison sheet
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • DALI GW Comparison sheet
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
Back to SpaceLogic KNX Forum
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-09-16 11:47 PM
1294
Dear Team,
I’ve noticed a wide range of DALI gateways available. Previously, I worked with models MTN6725-0001 and MTN6725-0101. When the Basic DALI gateway introduced support for controlling ECGs and groups, I initiated a new project using that version.
Recently, I came across the DALI Broadcast Master, which appears to be more modern and feature-rich. In hindsight, I wish I had selected it for my current project instead of the Basic model.
Could you kindly share a comparison sheet outlining the advantages of each gateway? Additionally, if there are any models scheduled for discontinuation, I’d appreciate that information as well.
Best Regards,
  • SpaceLogic devices
Thomas_Rohde
Sisko
Posted: ‎2025-09-26 03:49 AM
Hello IC_Systems!
Here we go 😉
Kind regards
Thomas
Application Design Engineer
Replies 5
Thomas_Rohde
Sisko
Hello IC_Systems!
Here we go 😉
Kind regards
Thomas
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-09-28 12:03 AM
1216
Thank you @Thomas_Rohde
The Broadcast Gateway controls all channels by transmitting the same value across them, without the ability to adjust individual ECG/DALI channel levels. As a result, all channels function as a single group?
Best Regards,
Erwin-vd-Zwart
Janeway
Posted: ‎2025-09-28 10:32 PM
Each channel works as a group, not all channels..
Thomas_Rohde
Sisko
Posted: ‎2025-09-29 12:07 AM
Hello IC_Systems!
As Erwin already mentioned ... all ECGs within a channel are working as a single group.
But the device has 4 channel which are independend to each other.
Within the next monthes there will be also Extensions available.
Means, as normal within SpaceLogic, you will be able to connect up to two extensions with also 4 channel each.
So in maximum you can realize up to 12 different DALI channel.
Kind regards
Thomas
IC_Systems
Captain IC_Systems
Captain
Posted: ‎2025-09-29 05:24 AM
Thank you @Thomas_Rohde  and @Erwin-vd-Zwart
I intended to refer to each channel individually, but I mistakenly wrote 'all'
Thank you for the clarification.
Best Regards,
