Hello dears,
I see in the ETS catalogue two DALI GW Basic, while the Spacelogic one have ECG Control capability, as I know the BASIC GW control Groups only!
please see attached images
Hello IC_Systems!
To "I see in the ETS catalogue two DALI GW Basic..."
YES, this is correct.
To "while the Spacelogic one have ECG Control capability ..."
To "as I know the BASIC GW control Groups only!"
Yes&No, this depends on the used FW/ETS-Appl./DCA Version.
Please take a look on the overview attached.
Hello IC_Systems!
Thank you @Thomas_Rohde for your support and quick response.
I confused about this feature : "Overtake existing DALI-configuration from ECGs " if you could explain.
Please find below an explaination picture.
but does it work if existing ECGs are configured using SE DALI GW?
Also, I see multiple groups assignments! is it supported?
Hello IC_Systems!
To "but does it work if existing ECGs are configured using SE DALI GW"
Yes, this feature was already implemented within the old premium DALI GW.
To "Also, I see multiple groups assignments! is it supported?"
Yes, correct.
