Cannot load application List, while having internet access on SL
SpaceLogic KNX Forum
Select a Country
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Cannot load application List, while having internet access on SL
Thomas_Rohde
Thomas_Rohde Champion
141
Erwin-vd-Zwart
Erwin-vd-Zwart Champion
63
Heribert_Dölger
Heribert_Dölger Leader
36
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
IC_Systems
IC_Systems
Mentor
Posted: ‎2022-06-29 12:30 AM . Last Modified: ‎2024-07-14 11:44 PM
3119
Hello
I cant access the application page.
While I Ping to google.com, 8.8.8.8 and all success
Also I have another SL on the same network and could access the application page, and both have the same DNS Settings!
What could be the issue?
Best Regards,
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
Thomas_Rohde
Champion
Posted: ‎2022-06-29 05:09 AM
3099
Hello IC-Systems,
it should work with both FW-Versions but it can happen from time to time that it "for what ever reason" will not work.
This is then not general issue just appearing from one minute to the other.
How to go on:
- If there is a certain reason why you stick to FW2.6 then please try later again to reach the market place.
- If there is no certain reason just make the update to FW2.7 and check again (just a trial)
Kind regards
Thomas
Application Design Engineer
Replies 20
Thomas_Rohde
Champion
Posted: ‎2022-06-29 02:05 AM
3115
Hello IC-Systems,
different Firmware? Really the same settings ... no typo or similar?
Can you share the network- settings (picture)?
Kind regards
Thomas
IC_Systems
IC_Systems
Mentor
Posted: ‎2022-06-29 03:17 AM . Last Modified: ‎2022-06-29 04:32 AM
3112
Hello @Thomas_Rohde
I Sent You screen Shot for network settings.
While one (working application) in version 2.7.0, the other in version 2.6.0
Best Regards,
Thomas_Rohde
Champion
Posted: ‎2022-06-29 04:28 AM
3104
Hello IC-Systems,
the network settings looks good. Which device has which FW and which is not running as expected?
Kind regards
Thomas
IC_Systems
IC_Systems
Mentor
Posted: ‎2022-06-29 04:33 AM
3101
Hello @Thomas_Rohde
The one with FW 2.6.0
Best Regards,
Thomas_Rohde
Champion
3100
Hello IC-Systems,
How to go on:
Kind regards
Thomas
IC_Systems
IC_Systems
Mentor
Posted: ‎2022-06-30 07:26 AM
Thanks @Thomas_Rohde
Issue Solved after upgrade
Best Regards,
Amr-LSEGYPT
Amr-LSEGYPT
Explorer
Posted: ‎2023-01-11 02:59 AM
3080
i have the same problem and i upgrade firmware to 2.8 but i have the same problem?
what should I do?
Thomas_Rohde
Champion
Posted: ‎2023-01-11 04:40 AM
Hello Amr-LSEGYPT,
you mean that you cannot load application list, while having internet access on SL ... right?
What have you done to clearly be sure that you have internet access on your SL?
Are you working with DHCP or a fixed IP? In case of fixed IP ... did you set all necesarry entries like Gateway IP and DNS-Server1&2?
Only when these settings are correct, W4K/SL can have a proper access to the internet.
Please share/check your settings.
Kind regards
Thomas
Amr-LSEGYPT
Amr-LSEGYPT
Explorer
Posted: ‎2023-01-11 05:07 AM
3073
I set all setting
IP and gateway and DNS 1,2
Same problem
Thomas_Rohde
Champion
Posted: ‎2023-01-11 05:21 AM
Hello Amr-LSEGYPT,
can you check if you can reach google.com or 8.8.8.8 by the use of the network utilities?
Kind regards
Thomas
Amr-LSEGYPT
Amr-LSEGYPT
Explorer
Posted: ‎2023-01-11 05:56 AM
Network unreachable
Amr-LSEGYPT
Amr-LSEGYPT
Explorer
Posted: ‎2023-01-11 06:00 AM
3068
IP 192.168.0.10
255.255.255.0
192.168.0.0
8.8.8.8
8.8.4.4
Same to my laptop with different range of IP
Thomas_Rohde
Champion
Posted: ‎2023-01-11 06:09 AM
Hello Amr-LSEGYPT,
to be honest I am not a network specialist but I wonder about your gateway address with 192.168.0."0".
I think I have never seen "0" at the end only "1"?! Anyhow ...
What do you mean with "Same to my laptop with different range of IP"?
Do you mean only that you have a different IP-Address of your PC?
How big is your network? Is there maybe a router in between blocking?
Can you maybe take the SL into a little test-network?
Kind regards
Thomas
Amr-LSEGYPT
Amr-LSEGYPT
Explorer
Posted: ‎2023-01-11 06:18 AM
I mean IP for my PC is
192.168.0.100
255.255.255.0
192.168.0.1
IP for my wiser is
192.168.0.10
255.255.255.0
192.168.0.1
DNS1
8.8.8.8
I used hotspot wifi to let my PC have a network  and I connect my Spacelynk to my laptop direct
Thomas_Rohde
Champion
Posted: ‎2023-01-11 06:34 AM
Just to understand your network correctly ...
You have a setup like this where your mobile provides the internet by working as a hotspot?
Kind regards
Thomas
Thomas_Rohde
Champion
Posted: ‎2023-01-11 06:50 AM
Kind regards
Thomas
Amr-LSEGYPT
Amr-LSEGYPT
Explorer
Posted: ‎2023-01-11 08:56 AM
I tried to use router and I connect my laptop to router port and Spacelynk to another one port
And I did all configuration but I have the same error when trying to load the list
Thomas_Rohde
Champion
Posted: ‎2023-01-11 11:58 PM
Just for me to understand correctly. You have architecture 1 or 2?
Kind regards
Thomas
Amr-LSEGYPT
Amr-LSEGYPT
Explorer
Posted: ‎2023-01-12 12:34 AM
Solved Thanks
It turns out that it was a problem with the firewall
Thomas_Rohde
Champion
Posted: ‎2023-01-12 12:46 AM
Super!
Kind regards
Thomas
