Bacnet Client Script
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • Bacnet Client Script
Thomas_Rohde
Sisko Thomas_Rohde Sisko
130
Erwin-vd-Zwart
58
Heribert_Dölger
31
FZetina
Commander FZetina Commander
29
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
RobertMc
RobertMc Cadet
Cadet
Posted: ‎2024-05-08 09:26 AM . Last Modified: ‎2024-07-14 11:39 PM
786
require('bacnet')
device, objects = bacnet.scandevice(ID)
Fails with Bacnet module not found.
SpaceLYnk 2.8.3.
Is this an installable extra module?
Robert.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • SpaceLYnk
  • Wiser for KNX
Replies 4
Thomas_Rohde
Sisko
Posted: ‎2024-05-21 06:11 AM
723
Hi RobertMc,
do you have a special need/requirement to realize the bacnet communication via script?
Can you please share more details to understand your topic better please?
Kind regards
Thomas
Application Design Engineer
murzilka
Crewman murzilka
Crewman
Posted: ‎2024-08-19 11:12 PM
Hi! I have the some question as topicstarter.
The reason is to use at the same time the Bacnet server and client.
Erwin-vd-Zwart
Janeway
Posted: ‎2024-08-20 07:26 AM
Even with script (and yes this requires to install an unsupported plugin) you cannot use server and client at the same time due to a port conflict, both server and client will use same port 0xBAC0 to 0xBAC9 (47808 - 47817)
Neskettani
Administrator Neskettani Administrator
Posted: ‎2024-10-09 07:25 AM
Hello @RobertMc  have you found a solution to your problem?
Nesrine Kettani
KNX Community Reference
