BACnet integration to external BMS/BAS LSS100200
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • BACnet integration to external BMS/BAS LSS100200
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
PiotrJakubczyk
Sisko PiotrJakubczyk Sisko
Sisko
Posted: ‎2021-09-13 07:10 AM . Last Modified: ‎2024-07-14 11:46 PM
872
Hello
Is there a way to maintain BACnet addressing when exporting KNX objects to BACnet?
Example: when i have almost ready solution I'm exporting points to BACnet and i have some BACnet addressing. When for some reason adding another two points to BACnet, entire addressing changes unexpectedly.
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Protocols
  • Scripts
  • SpaceLYnk
Tags (5)
  • addressing
  • bacnet
  • exporting
  • knx
Erwin-vd-Zwart
Janeway
Posted: ‎2021-09-13 07:35 AM
This should be impossible, the instance is calculated from the group address like =SUM((A1*8*256)+(B1*256)+C1). so 2048 is 1/0/0
Erwin-vd-Zwart
Janeway
