BACnet Client scan fail
SpaceLogic KNX Forum
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic KNX Forum
  • BACnet Client scan fail
Thomas_Rohde
Sisko Thomas_Rohde Sisko
132
Erwin-vd-Zwart
60
Heribert_Dölger
31
SpaceLogic KNX - 4ʺ Touch Unit
KNX Push Button Dynamic Labeling, universal
Wiser for KNX : logic controller
Back to SpaceLogic KNX Forum
a_belfils_contr
Crewman a_belfils_contr
Crewman
Posted: ‎2022-12-05 04:42 AM . Last Modified: ‎2024-07-14 11:43 PM
1373
I have on project, one LSS100100 and 1 gateway Bacnet/M-BUS.
I need integrat many counter on LSS100100. When i scan device, Wiser or Spacelynk not found device.
I tried with version, 2_6_0, 2_6_2, 2_7_0, 2_8_0 on LSS100100 LSS100200.
I use Yabe for scan device and with this program it's ok.
See pictures for more detail.
Have you an idéa for help me ? This problème is know your service ?
Thanks lot.
Anthony Belfils
  • Thumbnail of SpaceLogic KNX - 4ʺ Touch Unit
  • Thumbnail of KNX Push Button Dynamic Labeling, universal
  • Thumbnail of Wiser for KNX : logic controller
View products (3)
  • Local App
  • Protocols
  • SpaceLYnk
  • Wiser for KNX
Erwin-vd-Zwart
Janeway
Posted: ‎2022-12-05 05:37 AM
1359
Hmm, don't understand why the SL is popping up in your scan results when the server is disabled..
Can you try to enable the server once and then disable it again to see if it stops showing up in YABE?
Replies 6
Erwin-vd-Zwart
Janeway
Posted: ‎2022-12-05 04:53 AM . Last Modified: ‎2022-12-05 04:58 AM
1368
@a_belfils_contr
It looks like you also have the server enabled ( i see the SL device in Yabe indicating that the server is enabled), can you disable the BACnet server under System - > Network -> BACnet settings?
You cannot use the client and server at the same time as they both use port BAC0 and you will have a port conflict.
Next to that you mentioned "I need integrat many counter on LSS100100", can you specify "many" ?
The client is limited to host a limited amount of objects, if you have to much objects you might notice strange behaviour.
BR,
Erwin
a_belfils_contr
Crewman
Posted: ‎2022-12-05 05:10 AM
1363
My server is not activat.
Max object for M-BUS is 25, i think it's ok no ?
Thanks.
Erwin-vd-Zwart
Janeway
1360
a_belfils_contr
Crewman
Posted: ‎2022-12-05 06:01 AM . Last Modified: ‎2022-12-05 06:03 AM
1354
I try activat, restart yabe and this is screenshot with the processus add Bacnet
And after desable server bacnet, restart LSS100200 and process down. Same on Yabe ...
After few minutes, when i try scan device another process call bacepics1 start
a_belfils_contr
Crewman
Posted: ‎2022-12-05 06:10 AM
1351
I change port of Bacnet 47809
See Yabe : Two server ??
a_belfils_contr
Crewman
Posted: ‎2022-12-05 06:16 AM
Ok, i uninstall Bacnet Client, now it's ok with server
without server
