Hi, What devices support this modes (2 modes - Curtain Step/move or Curtain position)? I have Master Switch/Blind device MTN6705-0008. It is not support such mode.. I have somfy RTS motors for curtains, ( 4 signals should be used - Open, Close and Stop - 3 wires + gnd/common..). I just wrote script for Master switch devise 3 outputs (script on SpaceLynk), it is working but not so convenient..
Just wanted to know with which devices this 2 curtain control modes are directly working (for future).
May be curtain mode also should be added for Master Switch/Blind MTN6705-0008 device and its extensions.
BR,
Alexander
Hi Tomas,
thank you for answer.
For this problem solving and for others (garage door open, gates open etc) would be good to implement in future for any knx button from SE and Master/blind devices as input mode (in Master/blind may be possible control output using staircase timer mode with very short delays, but not tested it) provide pulse mode (short impulse from 0 to 1 or from 1 to 0 (configurable) and pulse time (configurable).
This simply gives additional possibility control gates, curtains solutions where just pulse command is needed. Also it gives +1 point π to solution decentralization (no scripts from smart controller will be needed)..
BR,
Alexander
Hi Alexander,
I need to say that we do not have a dedicated product which supports these kind of motors out of the box.
Hi Tomas,
BR,
Alexander
Great!
Many THANKS for your help in improving our products!
