Which hardware should be used to integrate Zigbee with Wiser II?
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • Which hardware should be used to integrate Zigbee with Wiser II?
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant KCWong Lieutenant
4
ZeeZee97
Administrator ZeeZee97 Administrator
1
Back to SpaceLogic C-Bus Forum
sesa8875
sesa8875 Schneider Alumni (Retired)
Posted: ‎2014-04-08 08:39 PM
793
Is there other limitations for the number of Zigbee points?
KCWong
Lieutenant
Posted: ‎2014-04-10 10:29 PM
There will be 2 Zigbee interface can connect to WIser II. uZI(USB type, plug inside the WiserII) and eZI(ethernet type by hardwire connect within the same customer network with Wiser II).
KCWong
Lieutenant
