What are the requirements in order to control Wiser II through TV interface?
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • What are the requirements in order to control Wiser II through TV interface?
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant KCWong Lieutenant
4
ZeeZee97
Administrator ZeeZee97 Administrator
1
Back to SpaceLogic C-Bus Forum
sesa8875
sesa8875 Schneider Alumni (Retired)
Posted: ‎2014-04-08 08:47 PM
893
Do we need specific equipment? Do we need a specific TV set?
sesa96364
Posted: ‎2014-04-16 10:16 PM
Wiser 2 can be connected directly to TV using an HDMI cable.
This will display the Wiser 2 on the TV.
The Wiser 2 can be controlled through the TV using the TV remote provided the TV has the HDMI CEC feature.
If the TV doesn't support HDMI CEC you can use any USB HID compliant keyboard or mouse.
Posted: ‎2014-04-16 08:55 PM
Cbus IR transmitter or Minnder Pro
sesa96364
