Spacelogics Dimmer 5508D1D Stuck in Bootloader
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
Send InviteCancel
2024-11-1006:24 PM
Hi Admins,
I have a new 8 channel dimmer that appears to be stuck in bootloader mode. I was completing a firmware upgrade and an error occurred part way through. The unit is no longer responsive to commissioner or toolkit and the CBUS light is solid yellow. A power cycle didn't resolve the issue as per the troubleshooting guide.
Is there a mechanism by which the unit can be hard reset?
