AC control on eDLT
SpaceLogic C-Bus Forum
Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
  • EcoStruxure Building
  • Light and Room Control
  • SpaceLogic C-Bus Forum
  • AC control on eDLT
sesa96364
sesa96364 Schneider Alumni (Retired)
9
KCWong
Lieutenant KCWong Lieutenant
4
ZeeZee97
Administrator ZeeZee97 Administrator
1
Back to SpaceLogic C-Bus Forum
nigel_greenwave
Admiral | EcoXpert Master nigel_greenwave Admiral | EcoXpert Master
Posted: ‎2024-09-29 11:59 PM
653
AC control on eDLT
Is it possible to add a AC setpoint and fan speed control button on a eDLT?
The plan is, if it's possible to have these AC button on a eDLT, we would send the control signals via BACnet IP to the AC unit using a ASP.
Digby_Brock
Ensign Digby_Brock
Ensign
Posted: ‎2024-10-03 12:59 AM
Depends how you want to work,
One way could be to set 2 buttons up on the EDLT, using scene cycle or scene select, and setting the action selector for the scenes as the setpoint value. This would give you a range of 8 values to nudge up / down for setpoint adjustment (provided the edlt is not already using any scenes ).
The other button can be set as fan controller which would give 4 values, off, low, medium high.
Alternativly if you have a 5500AC or 5500NAC on the project a script could be written to increase or decrease a dummy group value on each button press.
