Schneider Electric forum about the C-Bus platform to get support and share knowledge including Network Automation Controller (NAC), Application Controller (AC) at selection, installation and troubleshooting sides.
This can now be achieved easily by using Modbus RTU ( RS485) or Modbus TCP (ethernet) compatible meters
connecting back to a 5500NAC controller (with built-in web server).
The 5500NAC provides trending / logging ability for the modbus meters also and can export the trend logs to an external location such as FTP server or embedded a link into an email.
5500NAC also has built-in BACnet Server for 500 Bacnet points, allowing a BMS (BACnet IP compatible) to retreive and display the infromation from the meters and also C-bus on your BMS.
There is a smaller capacity domestic unit called a 5500SHAC, however that only supports 6 Modbus Devices and 50 BACnet points, hence the 5500NAC is the better option for most modbus metering type projects.
