connecting contactor TeSys Deca frame 3 on UL feeder circuit
Send InviteCancel
Posted: 2021-06-2405:49 AM
The contactors TeSys Deca frame 3 can now be connected to a feeder circuit following UL requirement, using two mandatory large spacing adapters GV3G66 on top and bottom connections.
