Reduce Costs and Boost Asset Uptime with Motor Management
  • Industrial Automation
  • Solutions for Motor Management
  • Reduce Costs and Boost Asset Uptime with Motor Management
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
TeSys T
TeSys island
TeSys U
field url
Altivar Process (Low Voltage)
field url
Altivar Process (Medium Voltage)
field url
Altivar Machine
field url
Altivar Softstarter
Load more
Back to Solutions for Motor Management
Henry_KIM
Ensign Henry_KIM Ensign
Ensign
Posted: ‎2021-06-16 01:37 PM . Last Modified: ‎2022-02-09 04:44 AM
Why motor management?
On average, electric motors consume approximately 60% of the electricity produced to support manufacturing industries and drive critical infrastructure assets such as conveyor belts, pumps, compressors, agitators, fans, and others. However, despite their key operational role, traditional motor management approaches often fail to optimize performance.
Having one strategy that integrates motor control and protection solutions can help plants simultaneously reduce costs while increasing production. Robust connection and communication between the motor and the automation systems play an important role in minimizing instances of motor failure. In addition, overall energy costs are reduced when energy data from motors is monitored so that function can be better aligned to workload.
Key enablers for migrating to advanced motor management
Implementing a more holistic motor management strategy requires careful planning and the right combination of technologies. Traditionally, most companies have failed to pursue the integration of motor control, automation, and energy systems because of the perceived technical complexities. Fortunately, thanks to technology breakthroughs and new trends such as digitization and the Industrial Internet of Things (IIoT), advanced connectivity makes the implementation of a comprehensive motor management strategy affordable and feasible.
Find more information
For the Key elements that impact an advanced motor management strategy please visit here to access the full blog article about Motor Management  and learn more about Schneider Electric's motor management solution architectures.
Thank you.
  • Digitalization
  • Energy Efficiency
  • Power Quality
  • Products
  • Selection & sizing
Replies 0
