WELCOME to Motor Management Community!
  • Industrial Automation
  • Solutions for Motor Management
  • WELCOME to Motor Management Community!
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
Zirwa
Crewman Zirwa Crewman
Crewman
Posted: ‎2022-10-14 04:05 AM . Last Modified: ‎2023-04-27 05:33 AM
9
9747
Get latest news for Motor Management Solution
What is Motor Management Forum about?
This forum is specifically designed for specifiers, panel builders, distributors, business and technical experts, to connect and be a part of solution provider which helps controls and protect their motor and its management with the highest sustainability.
Reduce costs and Boost Asset Uptime with Motor Management
Get support for all our Motor Management Solutions:
  • Variable Speed Drives (Altivar)
  • Soft Starters (Altivar)
  • DOL (TeSys, TeSys Island)
Connect with experts who express their knowledge and discuss real-world experiences to answer your specific needs.
Never miss your favorite topics updates
Subscribe to labels matching with your own scope once you are on the Motor Management forum and get notified for new posts & responses. Simply specify the questions and choose the relevant label and get Expert advice about:
  • Product launches
  • Commissioning
  • Troubleshooting
  • Selection & Sizing
  • Firmware updates
  • Cybersecurity
  • Performances & Architecture
  • Legacy drives migration
What you need to do to get started
New to the Community? Get started with Your First steps with Schneider Electric Communities
You can also discover our community with this short video:
Pro-tip: Take advantage of the auto-translate feature to ask questions in your local language and translate posts that are interesting for you.
Subscribe now to activate daily notifications and never miss a thing
Get notifications for the latest update
  • Best Practice
  • Design & Build
  • Digitalization
  • Energy Efficiency
  • Power Quality
  • Products
  • Selection & sizing
  • Training & How to
LeoLazzaro
Lieutenant
Posted: ‎2023-03-30 08:47 AM
In response to Farooq8899
8963
Dear, I have checked the picture in this size of drives the fans are runing as soon you give the run order . In big power the fans are not manage by the termperature of the sensor , then Fans must work all the time during runing. The fans are in the bottom in this size. Maybe they are stuck and are  not runing properly.  The sensor is the heatsink , no easy to access and for this type of intervension I recommend you to reach the official Schneider Electric  local service .  For other side , in the installation manual is written how to supply the fans by external supply ( picture with yellow label) , but first you must to be sure that fans are working.
Replies 9
Farooq8899
Crewman Farooq8899
Crewman
Posted: ‎2023-03-27 03:32 AM
9027
Good afternoon.
I hope you are doing well.
We are facing this problem.
Can you suggest me , how can we solve this problem .
BJacqz
Commander
Posted: ‎2023-03-27 05:04 AM
This fault result on high torque demand from motor, I advise you to have a look on this article : What are some steps to troubleshoot fault code OHF on an ATV61 and ATV71 drive (Overheating faults)?...
As well as on attached note.
Bruno Jacqz, Drives training leader
LeoLazzaro
Lieutenant
Posted: ‎2023-03-27 05:08 AM
5
9013
Hello Farooq88  , Thank you for your question
Drive overheating means that hetsink reach a high temperature , you can check the THD ( drive thermal status) value in the HMI . It is in % , and the fault is trigger when this value reach 118% . Generally this fault is related to the following root causes
* Ambient temperature too high
* Bad enclosure cooling.
* Enclosure Inlet air Filter blocked.
* Fan failure.
Please could you share with us the ATV71/61 commercial reference.?
Thank you in advance
B.R.
Farooq8899
Crewman Farooq8899
Crewman
Posted: ‎2023-03-27 08:43 AM
In response to LeoLazzaro
9001
Good evening sir,
Thank you for good response.
Your are right sir, when thermal status reach 118 , then alarm appear, 2 days before I clean heatsink and air blower and also clean filters.
All fans are working properly.
I put one window AC front of power card , now thermal status is under 100 % . But I fell blower fan not going on proper time. I want to start fan early.
Please sir give me more suggestions untill solve this problem.
BJacqz
Commander
Posted: ‎2023-03-29 08:38 AM
8991
Small remark is may be to check the Motor switching frequency (PWM) and decrease it (if it is not already on mini possible). setting is SFR.
Farooq8899
Crewman Farooq8899
Crewman
Posted: ‎2023-03-29 10:28 PM
In response to BJacqz
8980
Good morning Sir, I hope you are doing well.
Can you you help me to find the temperature sensors of power board.
Can you send me the pictures temperature sensors, may be the sensor is not working properly.  I am sending two pictures. In this time thermal state is low but fan is running.
Kevin_McDonald
Ensign Kevin_McDonald Ensign
Ensign
Posted: ‎2023-03-30 04:49 AM
Drive overheat happens when the Drive thermal state reaches 118%.  You can monitor this under the Monitor menu.  For overheat faults, you need to first check and confirm the heatsink fans are running.  If you can provide the drive part and serial numbers, we can provide more specific details on where you may be able to check the fans and also part numbers for replacement if needed.
LeoLazzaro
Lieutenant
8964
LeoLazzaro
Lieutenant
Posted: ‎2023-03-30 08:51 AM
https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=ATV71E_Installation...
Check page 70
