TeSys island in Safety Applications
  • Industrial Automation
  • Solutions for Motor Management
  • TeSys island in Safety Applications
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
TeSys island
Back to Solutions for Motor Management
Posted: ‎2021-03-26 04:53 AM
1
1618
I am building a machine for stone crushing and it requires also Safety contactors. Is it possible to use TeSys island in such an application?
Looking forward to your feedback!
Mikael
  • Design & Build
TeSys_island
TeSys_island Schneider Alumni (Retired)
Posted: ‎2021-03-30 12:32 AM
Hello MikaelKoch,
nice to see more Questions from you.
Seems you are quite active with TeSys island.
Sure TeSys island can be also used for applications where are Safety needed.
For that we have Safety starters available.
They are quite easy to identify. Like all our components for Safety applications they ere red.
You can find our SIL Starters here: https://www.se.com/ww/en/product-range/65746-tesys-island/14189038670-power-devices/?N=1260739224
Also if you configure a TeSys island in our Configurator just use the SIL Avatar's.
You can find our configurator here: https://www.se.com/ww/en/work/products/industrial-automation-control/tools/motor-control-configurato...
TeSys_island
Hello MikaelKoch,
