Speed not increase
  • Industrial Automation
  • Solutions for Motor Management
  • Speed not increase
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Back to Solutions for Motor Management
msidd
Crewman msidd
Crewman
Posted: ‎2022-09-07 09:38 PM
1
1174
Speed not increase
down-speed of Overhead Crane is not increase by Shinader altivar71 as I set 87Hz rated speed in maximum frequency(Ffr) and 50hz in high speed frequency (hsf) , only option in hsf is 50hz and 60hz.
when we push a button speed increase but not that much increase if I compare to previous one. because our drive is faulty so I change drive which is also same as previous one.
can I get parameters from shinader drive altivar71 from pc, as display of drive is not show anything!?
In shinader altivar71 parameters show in short form how can we change to get full
description so that I can check motor running rpm on drive?
BJacqz
Commander
Posted: ‎2023-03-17 09:27 AM
This is possible to get connection from Drive to Computer using the "SoMove software", this is available as a freeware on SE.com. You can use this link : SoMove Software | Schneider Electric USA (se.com).
Next topis is you have also to download the DTM of your Schneider Altivar ATV71, this is available on same adress. Afterward, you will find also some how to video showing the way to use ATV71 with SoMove have a look at the following link : (1) How to program Parameter set switching on ATV71 drive via SoMove - YouTube
Bruno Jacqz, Drives training leader
BJacqz
Commander
