Short Circuit Fault on Softstarter but not in DOL
  • Industrial Automation
  • Solutions for Motor Management
  • Short Circuit Fault on Softstarter but not in DOL
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Set Series
Motorpact
Back to Solutions for Motor Management
cp1270
cp1270
Cadet
Posted: ‎2023-09-27 01:16 PM
879
Motorpact Softstarter trips on Short Circuit but not when in DOL mode - any suggestions?
  • Soft Starters
Delcho_Penkov
Lieutenant JG Delcho_Penkov Lieutenant JG
Lieutenant JG
Posted: ‎2023-09-29 10:12 AM
yes this does not sound normal. Have you checked the connections? What is the driven application?
Best regards,
Jesusd45
Jesusd45 Cadet
Cadet
Posted: ‎2025-02-24 07:46 AM
Hi, were you able to solve the problem?
