Replacing AC Coil on a TeSys D Series Contactor
  • Industrial Automation
  • Solutions for Motor Management
  • Replacing AC Coil on a TeSys D Series Contactor
BJacqz
Commander BJacqz Commander
49
LeoLazzaro
Lieutenant LeoLazzaro Lieutenant
16
PriscilaCunha22
Lieutenant JG PriscilaCunha22 Lieutenant JG
15
Bastian_Schmitz
11
Back to Solutions for Motor Management
TeSysMen
Ensign TeSysMen Ensign
Ensign
Posted: ‎2021-04-26 12:49 AM . Last Modified: ‎2021-04-26 12:51 AM
hi,
If you ordered wrong product reference, if you had an issue with the coil or either if you want to optimize your stock of product and adapt the contactor coil at last minute, here the procedure to replace the coil on AC contactor coil.
PS: Please remember you cannot do this on DC coil like 24VDC contactor because it is not designed to be replaced on DC coil.
  • Training & How to
  • coil
  • coil burnt
  • coil replacement
  • contactor
  • TeSys Deca
Replies 0
